Hotplug USB Drive, automount and udev
the USB drive mounts and unmounts into /media folder, but only read-only.
How do I have to change the udev-rule, to mount the device with read-write access.
Or do I have to create a seperate rule/script and how would it look like?
Changing /etc/fstab is not an option for me, because when the USB drive is unplugged, the folder (named by usb-drive label) is not deleted. I use the creation/deletion of the folder to recognize if an USB drive is plugged in or not.
To ensure your USB drive mounts with read-write access using udev rules, you can create or modify a udev rule to specify the desired mount options. Here’s a step-by-step guide to help you achieve this:
  1. Identify the USB Drive:
    • First, plug in your USB drive and use the lsblk or dmesg command to identify the device name (e.g., /dev/sda1).
  2. Create a Udev Rule:
    • Create a new udev rule file in /etc/udev/rules.d/, for example, 99-usb-mount.rules.
    • Add a rule to match your USB drive and specify the mount options. Here’s an example rule:
      ACTION=="add", SUBSYSTEM=="block", KERNEL=="sd[a-z][0-9]", ENV{ID_FS_TYPE}!="", RUN+="/usr/bin/mount -o rw,uid=1000,gid=1000 /dev/%k /media/%E{ID_FS_LABEL}"
    • This rule mounts the USB drive with read-write permissions and sets the owner to a specific user (replace uid=1000,gid=1000 with the appropriate user and group IDs).
  3. Reload Udev Rules:
    • After creating or modifying the rule, reload the udev rules with the following commands:
      sudo udevadm control --reload-rules
      sudo udevadm trigger
  4. Test the Configuration:
    • Unplug and replug your USB drive to test if it mounts with the specified options.
This approach allows you to manage USB drive mounting behavior without modifying /etc/fstab, maintaining the dynamic creation and deletion of mount points based on the drive’s presence.
I hope this helps you achieve the desired functionality for your USB drive.
Toradex AI Assistant
Define auto mountpoint for usb storage and hot plug.
The new udev-rule is not working for me.
Torizon 6.8
udev-rules:
10-imx.rules
10-toradex-net-rename.rules
90-toradex-gpio.rules
91-toradex-i2cdev.rules
92-toradex-spidev.rules
93-toradex-backlight.rules
94-toradex-pwm.rules
99-toradex.rules
99-usb-mount.rules
bootpart-automount.rules
touchscreen.rules
I can not write to the usb-drive with user ‘torizon’ (uid=1000,gid=1000).
udev monitor output: (USB Drive plugged in)
UDEV [492.211791] add /devices/virtual/workqueue/scsi_tmf_0 (workqueue)
UDEV [492.214269] add /devices/platform/soc@0/32f10108.usb/38200000.usb/xhci-hcd.1.auto/usb1/1-1/1-1.1 (usb)
UDEV [492.219631] add /devices/platform/soc@0/32f10108.usb/38200000.usb/xhci-hcd.1.auto/usb1/1-1/1-1.1/1-1.1:1.0 (usb)
UDEV [492.224808] add /devices/platform/soc@0/32f10108.usb/38200000.usb/xhci-hcd.1.auto/usb1/1-1/1-1.1/1-1.1:1.0/host0 (scsi)
UDEV [492.229486] add /devices/platform/soc@0/32f10108.usb/38200000.usb/xhci-hcd.1.auto/usb1/1-1/1-1.1/1-1.1:1.0/host0/scsi_host/host0 (scsi_host)
UDEV [492.233554] bind /devices/platform/soc@0/32f10108.usb/38200000.usb/xhci-hcd.1.auto/usb1/1-1/1-1.1/1-1.1:1.0 (usb)
UDEV [492.237709] bind /devices/platform/soc@0/32f10108.usb/38200000.usb/xhci-hcd.1.auto/usb1/1-1/1-1.1 (usb)
UDEV [493.278307] add /devices/virtual/bdi/8:0 (bdi)
UDEV [493.278931] add /devices/platform/soc@0/32f10108.usb/38200000.usb/xhci-hcd.1.auto/usb1/1-1/1-1.1/1-1.1:1.0/host0/target0:0:0 (scsi)
UDEV [493.284924] add /devices/platform/soc@0/32f10108.usb/38200000.usb/xhci-hcd.1.auto/usb1/1-1/1-1.1/1-1.1:1.0/host0/target0:0:0/0:0:0:0 (scsi)
UDEV [493.291791] add /devices/platform/soc@0/32f10108.usb/38200000.usb/xhci-hcd.1.auto/usb1/1-1/1-1.1/1-1.1:1.0/host0/target0:0:0/0:0:0:0/scsi_device/0:0:0:0 (scsi_device)
UDEV [493.293851] add /devices/platform/soc@0/32f10108.usb/38200000.usb/xhci-hcd.1.auto/usb1/1-1/1-1.1/1-1.1:1.0/host0/target0:0:0/0:0:0:0/scsi_disk/0:0:0:0 (scsi_disk)
UDEV [493.295799] add /devices/platform/soc@0/32f10108.usb/38200000.usb/xhci-hcd.1.auto/usb1/1-1/1-1.1/1-1.1:1.0/host0/target0:0:0/0:0:0:0/bsg/0:0:0:0 (bsg)
UDEV [493.374524] add /devices/platform/soc@0/32f10108.usb/38200000.usb/xhci-hcd.1.auto/usb1/1-1/1-1.1/1-1.1:1.0/host0/target0:0:0/0:0:0:0/block/sda (block)
UDEV [493.582446] add /devices/platform/soc@0/32f10108.usb/38200000.usb/xhci-hcd.1.auto/usb1/1-1/1-1.1/1-1.1:1.0/host0/target0:0:0/0:0:0:0/block/sda/sda1 (block)
UDEV [493.591507] bind /devices/platform/soc@0/32f10108.usb/38200000.usb/xhci-hcd.1.auto/usb1/1-1/1-1.1/1-1.1:1.0/host0/target0:0:0/0:0:0:0 (scsi)
UDEV [493.697732] change /devices/platform/soc@0/32f10108.usb/38200000.usb/xhci-hcd.1.auto/usb1/1-1/1-1.1/1-1.1:1.0/host0/target0:0:0/0:0:0:0/block/sda/sda1 (block)
torizon@verdin-imx8mp$ cat /proc/mounts
proc /proc proc rw,relatime 0 0
sysfs /sys sysfs rw,relatime 0 0
tmpfs /run tmpfs rw,nosuid,nodev 0 0
devtmpfs /dev devtmpfs rw,relatime,size=1731960k,nr_inodes=432990,mode=755 0 0
devpts /dev/pts devpts rw,relatime,gid=5,mode=620,ptmxmode=666 0 0
/dev/disk/by-label/otaroot /sysroot ext4 rw,relatime 0 0
/dev/disk/by-label/otaroot / ext4 rw,relatime 0 0
/dev/disk/by-label/otaroot /boot ext4 rw,relatime 0 0
/dev/disk/by-label/otaroot /usr ext4 ro,relatime 0 0
securityfs /sys/kernel/security securityfs rw,nosuid,nodev,noexec,relatime 0 0
tmpfs /dev/shm tmpfs rw,nosuid,nodev 0 0
tmpfs /sys/fs/cgroup tmpfs ro,nosuid,nodev,noexec,size=4096k,nr_inodes=1024,mode=755 0 0
cgroup2 /sys/fs/cgroup/unified cgroup2 rw,nosuid,nodev,noexec,relatime,nsdelegate 0 0
cgroup /sys/fs/cgroup/systemd cgroup rw,nosuid,nodev,noexec,relatime,xattr,name=systemd 0 0
pstore /sys/fs/pstore pstore rw,nosuid,nodev,noexec,relatime 0 0
bpf /sys/fs/bpf bpf rw,nosuid,nodev,noexec,relatime,mode=700 0 0
cgroup /sys/fs/cgroup/hugetlb cgroup rw,nosuid,nodev,noexec,relatime,hugetlb 0 0
cgroup /sys/fs/cgroup/devices cgroup rw,nosuid,nodev,noexec,relatime,devices 0 0
cgroup /sys/fs/cgroup/pids cgroup rw,nosuid,nodev,noexec,relatime,pids 0 0
cgroup /sys/fs/cgroup/cpu,cpuacct cgroup rw,nosuid,nodev,noexec,relatime,cpu,cpuacct 0 0
cgroup /sys/fs/cgroup/freezer cgroup rw,nosuid,nodev,noexec,relatime,freezer 0 0
cgroup /sys/fs/cgroup/memory cgroup rw,nosuid,nodev,noexec,relatime,memory 0 0
cgroup /sys/fs/cgroup/cpuset cgroup rw,nosuid,nodev,noexec,relatime,cpuset 0 0
cgroup /sys/fs/cgroup/net_cls,net_prio cgroup rw,nosuid,nodev,noexec,relatime,net_cls,net_prio 0 0
cgroup /sys/fs/cgroup/blkio cgroup rw,nosuid,nodev,noexec,relatime,blkio 0 0
cgroup /sys/fs/cgroup/perf_event cgroup rw,nosuid,nodev,noexec,relatime,perf_event 0 0
hugetlbfs /dev/hugepages hugetlbfs rw,relatime,pagesize=2M 0 0
mqueue /dev/mqueue mqueue rw,nosuid,nodev,noexec,relatime 0 0
debugfs /sys/kernel/debug debugfs rw,nosuid,nodev,noexec,relatime 0 0
tracefs /sys/kernel/tracing tracefs rw,nosuid,nodev,noexec,relatime 0 0
tmpfs /tmp tmpfs rw,nosuid,nodev,size=1999372k,nr_inodes=1048576 0 0
fusectl /sys/fs/fuse/connections fusectl rw,nosuid,nodev,noexec,relatime 0 0
configfs /sys/kernel/config configfs rw,nosuid,nodev,noexec,relatime 0 0
/dev/disk/by-label/otaroot /var ext4 rw,relatime 0 0
tmpfs /var/volatile tmpfs rw,relatime 0 0
tmpfs /run/user/1000 tmpfs rw,nosuid,nodev,relatime,size=399872k,nr_inodes=99968,mode=700,uid=1000,gid=1000 0 0
/dev/sda1 /var/rootdirs/media/CETA vfat rw,nosuid,nodev,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=iso8859-1,shortname=mixed,showexec,utf8,flush,errors=remount-ro 0 0
Greetings @Lars.ceta,
Just a suggestion. So the most straight-forward way I know to indicate mount options for USB drives automatically is via /etc/fstab. Now you say can’t use this method because:
Would it not be possible to just change your detection method and then use /etc/fstab. For example instead of looking at the folder why not look if there is a listed mount or if there is a /dev/sda* device connected as an indication that a USB drive is plugged. Or is there a reason you can’t do this in your system design?
I debugged udev-rules and found this lines:
Jan 30 07:14:32 verdin-imx8mp-14707144 systemd-udevd[1165]: sda1: ‘/usr/bin/mount -o rw,uid=1000,gid=1000 /dev/sda1 /media/CETA’(err) ‘mount: /media/CETA: mount point is not a directory.’
Jan 30 07:14:32 verdin-imx8mp-14707144 systemd-udevd[1165]: sda1: Process ‘/usr/bin/mount -o rw,uid=1000,gid=1000 /dev/sda1 /media/CETA’ failed with exit code 32.
Jan 30 07:14:32 verdin-imx8mp-14707144 systemd-udevd[1165]: sda1: Command “/usr/bin/mount -o rw,uid=1000,gid=1000 /dev/sda1 /media/CETA” returned 32 (error), ignoring
Maybe I need a script which creates the directory before mounting the device. Can anyone provide help?
Greeting @jeremias.tx,
it would be possible to use fstab. I did that already but was not happy with this solution. If I cannot find a udev-solution, I will switch back to fstab.
Lars
With udev rules you can designate a script/external program to be executed upon an event. In theory you could have a script that creates the mount directory and then mount it. More details here: You would just need to have the RUN argument point to your program/script.
