We recently released a version that fixes an issue where the .conf/.template file of a project created by the extension was wrongly deleted. The fix, however, only covers projects created with versions v2.4.1 and greater, which means a manual fix is required for existing projects created with versions under v2.4.1.
Already Created Projects Hotfix Instructions
This file is used by the update system to store the folder name of the template that was used to create the project. And itβs created and populated during the project creation only. So, if you get some log like this when trying to update the project:
Get-Content: /home/user/Toradex/IDE_projects/TestMonoProject/.conf/projectUpdater.ps1:69:17
Line |
69 | $templateName = Get-Content $projectFolder/.conf/.template
| Cannot find path '/home/user/Toradex/IDE_projects/TestMonoProject/.conf/.template' because it does not exist.
* The terminal process "pwsh '-nop', '/home/user/Toradex/IDE_projects/TestMonoProject/.conf/projectUpdater.ps1', '/home/user/Toradex/IDE_projects/TestMonoProject', 'TestMonoProject', '0'" terminated with exit code: 1.
* Terminal will be reused by tasks, press any key to close it.
It means that you are affected by the issue.
To solve it, create a new .template file inside the .conf/ folder from your project. This is a text file that contains exactly the folder name of the template used to create the project. Follow the table to check the name that you should use:
| .template Content | Template Used |
| aspnetBlazor | ASP.NET 8 Blazor Application |
| cConsole | C Console Application |
| cmakeConsole | C++ CMake Console Application |
| cppConsole | C++ Makefile Console Application |
| cppQML | C++ Qt 6 QML Application |
| cppSlint | C++ Slint Application |
| dotnetAvalonia | .NET 8 C# Avalonia GTK MVVM |
| dotnetAvaloniaFrameBuffer | .NET 6 C# Avalonia Frame Buffer DRM |
| dotnetConsole | .NET 8 C# Console Application |
| dotnetSlint | .NET Slint Application |
| dotnetUno | .NET 6 C# Uno Platform Skia.GTK |
| dotnetUno5 | .NET 8 C# Uno Platform 5.x Skia.GTK |
| dotnetUno5FrameBuffer | .NET 8 C# Uno Platform 5 Frame Buffer |
| dotnetUnoFrameBuffer | .NET 6 C# Uno Platform Frame Buffer |
| gambasForms | Gambas3 Form Project |
| genericTemplate | Generic Dockerfile Template (Without Language) |
| javaForms | Java Swing JFrame Application |
| monoCsharpForms | Mono 4.7 C# Windows Forms Application |
| nodeElectron | Node.js JavaScript Electron Application |
| nodeJSTypeScript | Node.js TypeScript Application |
| python3Console | Python 3 Console Application |
| python3Pyside2QML | Python 3 Pyside 2(Qt 5) QML Application |
| rustConsole | Rust Console Application |
| rustSlint | Rust Slint Application |
| tcb | TorizonCore Builder Project |
| zigConsole | Zig Console Application |
If you need further assistance to help you fix this issue on your side, please feel free to contact us.
