Hi all,
I am going through the process of allowing TEZI images to be hosted on our own web server and installed through the TEZI installer.
When I host the files on an SD card or USB key, they install and run correctly.
When I host them via a web server, they appear okay and install just fine.
However once installed, I get the prompt to reboot and once done I get nothing.
Only way to recover is to put the module in recovery mode and reprogram from there.
Any idea why the hosting of these files differs via a web server vs locally via USB or SD?
The web server is IIS running under Windows 11. Could the files become corrupt during the transfer? Do I need to apply any special settings on the web server?
Any advice would be appreciated.
Thanks,
James
