Hi Jaski,
I’m using an evaluation board V3.2B.
uname -a says:
Linux colibri-imx6 4.9.87-rt62-dirty #4 PREEMPT RT Wed Aug 8 17:32:48 CEST 2018 armv7l GNU/Linux
I’m using a bitrate of 2500000.
This is my complete code, I hope there is nothing wrong with it:
// std stuff
#include <stdio.h>
#include <string.h>
#include <unistd.h>
// socket stuff
#include <sys/types.h>
#include <sys/socket.h>
#include <sys/ioctl.h>
#include <net/if.h>
// can stuff
#include <linux/can.h>
#include <linux/can/raw.h>
#include <linux/can/error.h>
// pthread stuff
#include <pthread.h>
#ifdef GPIO
// gpio stuff
#include "gpio.h"
#define GPIO_PIN_NO 7
#endif
#ifndef COUNT
#define COUNT 1
#endif
static void *read_thread(void *arg)
int fd=(int)arg;
struct can_frame data;
while( read(fd, &data, sizeof(data)) > 0 )
if( data.can_id & CAN_ERR_FLAG )
if( data.can_id & CAN_ERR_TX_TIMEOUT)
printf("TX timeout (by netdevice driver)\n");
if( data.can_id & CAN_ERR_LOSTARB )
printf("lost arbitration: 0x%02hhx\n",data.data[0]);
if( data.can_id & CAN_ERR_CRTL )
printf("controller problems: 0x%02hhx\n",data.data[1]);
if( data.can_id & CAN_ERR_PROT )
printf("protocol violations: 0x%02hhx 0x%02hhx\n",data.data[2],data.data[3]);
if( data.can_id & CAN_ERR_TRX )
printf("transceiver status: 0x%02hhx\n",data.data[4]);
if( data.can_id & CAN_ERR_ACK )
printf("received no ACK on transmission\n");
if( data.can_id & CAN_ERR_BUSOFF )
printf("bus off\n");
if( data.can_id & CAN_ERR_BUSERROR )
printf("bus error (may flood!)\n");
if( data.can_id & CAN_ERR_RESTARTED )
printf("controller restarted\n");
else
printf("data frame received\n");
return NULL;
int main(int argc, char **argv)
int status=-1;
int fd;
// get a socket from os
fd=socket(AF_CAN, SOCK_RAW, CAN_RAW);
if(fd > 0)
struct ifreq ifr;
// get the interface index
strcpy(ifr.ifr_name, "can0");
if( !ioctl(fd, SIOCGIFINDEX, &ifr) )
struct sockaddr_can addr;
// bind the socket to the interface
addr.can_family=AF_CAN;
addr.can_ifindex=ifr.ifr_ifindex;
if( !bind(fd, (struct sockaddr *)&addr,sizeof(addr)) )
//can_err_mask_t mask=0x01ff; // gimme everything
can_err_mask_t mask=CAN_ERR_MASK; // gimme everything
pthread_t thread;
// set error filter
setsockopt(fd, SOL_CAN_RAW, CAN_RAW_ERR_FILTER, &mask, sizeof(mask));
// start receive thread
if( !pthread_create(&thread, NULL, read_thread, (void *)fd) )
struct can_frame data={
0x0100, // can_id
8, // payload length
0,0,0, // padding
{0x01,0x02,0x03,0x04,0x05,0x06,0x07,0x08}
ssize_t n;
int count;
#ifdef GPIO
GPIO_PIN_DAT gpio_pin;
gpio_pin.gpio_pin_no=GPIO_PIN_NO;
gpio_pin.gpio_set_dir=GPIO_DIR_OUT;
gpio_setup(&gpio_pin);
gpio_write_pin(&gpio_pin, LOW);
#endif
while(1)
#ifdef STEP
getchar();
#endif
#ifdef GPIO
gpio_write_pin(&gpio_pin, HIGH);
#endif
for(count=0; count<COUNT; count++)
n=write(fd, &data, sizeof(data));
//printf("%d bytes written\n",n);
#ifdef GPIO
#endif
else
perror("bind() failed");
else
perror("ioctl() failed");
close(fd);
else
perror("socket() failed");
return status;
Thanks.
