i want to hide the aws configuration file which is inside te board and overrife also if needed >
Hello!
Thank you for your question regarding AWS configuration on Verdin boards. While the documentation you referenced pertains to legacy Windows CE implementations, it’s important to note that this approach is outdated and not recommended for current systems.
For modern embedded Linux systems, including those running on Toradex hardware with Torizon, securely managing AWS credentials is crucial. Here are some general best practices you can follow:
Environment Variables: Store AWS credentials in environment variables rather than hardcoding them into your application. This approach keeps sensitive information separate from your codebase.
AWS IAM Roles: If your application is running on AWS infrastructure, consider using IAM roles to manage permissions securely without needing to store credentials on the device.
Secrets Management: Utilize a secrets management tool or service to store and access credentials securely. This can include AWS Secrets Manager or other third-party solutions.
Configuration Files: If you must use configuration files, ensure they are not included in version control and are stored securely on the device.
For more detailed guidance, you might find the following resources helpful:
These platforms can provide community-driven insights and examples that might align with your specific use case.
If you have any more questions or need further assistance, feel free to ask!
I couldn’t understand what you really want to achieve.
Please share more details about your issue, what you are doing right now, and what your expectations are with it.
Best regards.
Lucas Azeituno
