I’ve been using a Colibri iMX6 with a 800x600 LCD display(SVGA060SC) for my projects. The display is connected to the Generic RGB Display connector on my Colibri Eval V3.2B.
I’ve set the following vidargs:
vidargs=video=mxcfb0:dev=lcd,800x600M-24@60,if=RGB666 video=mxcfb1:off fbmem=24M
and fbset:
mode "800x600-60"
# D: 40.000 MHz, H: 37.879 kHz, V: 60.317 Hz
geometry 800 600 800 600 24
timings 25000 128 40 1 23 88 4
accel false
rgba 8/16,8/8,8/0,0/0
endmode
As a result, the screen displays a red stripe.
The software versions:
Colibri_iMX6_LinuxConsoleImageV2.6_20161128 (Angstrom v2015.12 -Linux-3.14.52-v2.6b2+g7c83cef)
