Hello world custom kernel module error
Hello all,
I am trying tu add a custom kernel module to my Boot2Qt image and so I am following these instructions to add an hello-world module
But when I am running
bitbake b2qt-embedded-qt5-image
or
bitbake hello-mod
I am getting this following error
ERROR: hello-mod-1.0-r0 do_package: QA Issue: hello-mod: Files/directories were installed but not shipped in any package:
/lib
/lib/modules
/lib/modules/5.4.129-0+git.cb88cc157bfb
/lib/modules/5.4.129-0+git.cb88cc157bfb/extra
Please set FILES such that these items are packaged. Alternatively if they are unneeded, avoid installing them or delete them within do_install.
hello-mod: 4 installed and not shipped files. [installed-vs-shipped]
ERROR: hello-mod-1.0-r0 do_package: Fatal QA errors found, failing task.
ERROR: Logfile of failure stored in: /home/inno-dev/BuildDir/VOH_OS/build-apalis-imx8/tmp/work/apalis_imx8-poky-linux/hello-mod/1.0-r0/temp/log.do_package.260735
ERROR: Task (/home/inno-dev/BuildDir/VOH_OS/sources/meta-voh/recipes-kernel/hello-mod/hello-mod_1.0.bb:do_package) failed with exit code ‘1’
What am I missing here?
Thanks for your help.
Edit:
When running
export MACHINE=apalis-imx8
source ./setup-environment.sh
bitbake hello-mod
I’ve got the error. But when running
export MACHINE=raspberrypi4
bitbake hello-mod
Everything works fine. So could it be that there is a configuration error with the imx-8 ?
Romain
Dear @Romain.Donze,
Can you please give us more information?
From where did you get the setup-environment.sh? Here on toradex we use . export as shown here: Build a Reference Image with Yocto Project/OpenEmbedded | Toradex Developer Center. You could also have a look on this page: Qt for Device Creation (Boot to Qt) | Toradex Developer Center
Also, I’d guess that for Raspberry the QA is not enabled. You could have a look here to understand more what that means: 9 QA Error and Warning Messages — The Yocto Project ® 4.1.999 documentation
Have you made any custom recipe? If yes, could you please share with us?
Thank you for your quick reply.
After some thinking and testing and with the rapsberry build working flawlessly, I went and did a complete clean and rebuild the complete image overnight and it worked.
I think I might had some corrupted files in my old build.
Everything seems fine now
