hello dear support
I’m going to design HDMI with a Colibri imx6
I’m designing 8 layer PCB and need to set the reference plane of the HDMI
but something is confusing me
which layer should I use for the reference?
1- flat GND that is in the X2 connector
2- imx6 power line GND?
3- any other ideas?
You can base your HDMI-related design on the Iris carrier board design. Although Iris employs a DVI-connector instead of HDMI, the signal lines are identical to HDMI’s. Please consult our Layout Design Guide as well.
dear josep
I am on it and i think i have found my solution
i will update it as soon as my board start working
thank you my friend
