I have imx6 module plugged into the custom board which has HDMI output. I connected the HDMI - HDMI display and powered on the unit. The display does not come up. Please help me out in bringing up the display. I shall be thankful to you.
Below are information about the environment::
Corresponding bootup logs are attached dmesg_log.txt (27.7 KB)
DTS file is also attached which we use for our custom board. It has been patched with custom changes as compared to standard eval board dts file imx6q-apalis-ixora-v1.1.dts (8.6 KB)
Yocto version is thud (2.6.4)
root@apalis-imx6:~# uname -a
Linux apalis-imx6 4.14.170-3.0.4+gbaa6c24240a4 #1 SMP Thu Jul 11 11:39:01 UTC 2024 armv7l armv7l armv7l GNU/Linux
(I am not sure which fb to use but I have observed that if other than fb0 used then I see error with the xrandr command
root@apalis-imx6:~# xrandr
X11 connection rejected because of wrong authentication.
Can’t open display localhost:10.0
root@apalis-imx6:~# xrandr -q
Screen 0: minimum 320 x 200, current 3520 x 1080, maximum 16384 x 16384
eDP-1 connected primary 1920x1080+0+0 (normal left inverted right x axis y axis) 344mm x 194mm
1920x1080 60.00*+ 59.97 59.96 59.93
1680x1050 59.95 59.88
1400x1050 59.98
1600x900 59.99 59.94 59.95 59.82
1280x1024 60.02
1400x900 59.96 59.88
1280x960 60.00
1440x810 60.00 59.97
1368x768 59.88 59.85
1280x800 59.99 59.97 59.81 59.91
1280x720 60.00 59.99 59.86 59.74
1024x768 60.04 60.00
960x720 60.00
928x696 60.05
896x672 60.01
1024x576 59.95 59.96 59.90 59.82
960x600 59.93 60.00
960x540 59.96 59.99 59.63 59.82
800x600 60.00 60.32 56.25
840x525 60.01 59.88
864x486 59.92 59.57
700x525 59.98
800x450 59.95 59.82
640x512 60.02
700x450 59.96 59.88
640x480 60.00 59.94
720x405 59.51 58.99
684x384 59.88 59.85
640x400 59.88 59.98
640x360 59.86 59.83 59.84 59.32
512x384 60.00
512x288 60.00 59.92
480x270 59.63 59.82
400x300 60.32 56.34
432x243 59.92 59.57
320x240 60.05
360x202 59.51 59.13
320x180 59.84 59.32
HDMI-1 disconnected (normal left inverted right x axis y axis)
DP-1 connected 1600x900+1920+0 (normal left inverted right x axis y axis) 698mm x 393mm
2560x1440 75.00 + 59.95
1920x1080 60.00 50.00 59.94
1680x1050 59.95
1600x900 60.00*
1280x1024 75.02 60.02
1440x900 59.89
1280x800 59.81
1152x864 75.00
1280x720 60.00 50.00 59.94
1024x768 75.03 70.07 60.00
832x624 74.55
800x600 72.19 75.00 60.32 56.25
720x576 50.00
720x480 60.00 59.94
640x480 75.00 72.81 66.67 60.00 59.94
720x400 70.08
DP-2 disconnected (normal left inverted right x axis y axis)
DP-3 disconnected (normal left inverted right x axis y axis)
DP-4 disconnected (normal left inverted right x axis y axis)
Based on the information provided, it seems that your HDMI display is not being detected or activated correctly with your i.MX6 module on a custom board. Here are several steps and checks to help troubleshoot and potentially resolve the issue:
Check Hardware Connections: Ensure that the HDMI cable is properly connected and the display is powered on. It might seem basic, but it’s often overlooked.
Verify U-Boot Video Arguments: The U-Boot environment variable vidargs you’ve set appears correct for enabling HDMI output. However, ensure that these settings are being applied correctly by checking the U-Boot boot log for any errors or warnings related to video output. You can also try simplifying the vidargs to a basic configuration to test functionality, for example:
Linux Kernel and Device Tree: Since you’re using a custom DTS file, ensure that the HDMI output is correctly configured in the device tree. This includes checking the HDMI node and its properties, such as status being set to “okay” and the correct phy settings. Given the custom nature of your board, compare your HDMI configuration with that of a reference board to spot any discrepancies.
X11 Configuration: The error with xrandr indicating “X11 connection rejected because of wrong authentication” suggests there might be an issue with your X11 configuration or the way you’re trying to run xrandr. Ensure you’re running it in a session where the DISPLAY variable is correctly set, for example:
export DISPLAY=:0
xrandr
This should be done in the graphical user session or with appropriate permissions.
Check Display Output with fbset: The fbset -s output shows that a framebuffer mode is set for 1920x1080, which is a good sign. However, ensure that the framebuffer device (/dev/fb0) is actually being used by your display server or application. You can test the framebuffer directly with tools like fbtest.
Kernel Logs: Since you mentioned having dmesg_log.txt, look for any messages related to the display, HDMI, or i.MX6 IPU and HDMI drivers. Warning or error messages could provide clues on what’s going wrong.
he Toradex Easy Installer is a stripped-down Linux version with a dedicated UI for image flashing. It is configured by default to output video to all available video interfaces, including HDMI. You can load it over USB OTG as described here.
If your HDMI interface is wired properly, you should see the Toradex Easy Installer UI on the connected HDMI display. If you have an Ixora carrier board, you can use it to verify this setup.
I followed the instructions mentioned in the following page.
When I run the image from USB using command run bootcmd_usb0 I get following error
Apalis iMX6 # run bootcmd_usb0
Device 0: Vendor: General Rev: 1100 Prod: USB Flash Disk
Type: Removable Hard Disk
Capacity: 3838.0 MB = 3.7 GB (7860224 x 512)
… is now current device
Scanning usb 0:1…
Found U-Boot script /boot.scr
2076 bytes read in 27 ms (74.2 KiB/s)
.#Executing script at 17000000
80 bytes read in 22 ms (2.9 KiB/s)
35209364 bytes read in 1385 ms (24.2 MiB/s)
Bootargs: console=ttymxc0,115200 quiet video=DPI-1:640x480D video=HDMI-A-1:640x480-16@60D video=LVDS-1:d video=VGA-l
.# Loading kernel from FIT Image at 14420000 …
Could not find configuration node
ERROR: can’t get kernel image!
SCRIPT FAILED: continuing…
Apalis iMX6 #
CPU: Freescale i.MX6Q rev1.6 at 792MHz
CPU: Industrial temperature grade (-40C to 105C) at 37C
Reset cause: POR
DRAM: 2 GiB
PMIC: device id: 0x10, revision id: 0x21, programmed
MMC: FSL_SDHC: 1, FSL_SDHC: 2, FSL_SDHC: 0
Loading Environment from MMC… OK
In: serial
Out: serial
Err: serial
Model: Toradex Apalis iMX6 Quad 2GB IT V1.1Y, Serial# 11167058
Net: using PHY at 7
FEC [PRIME]
starting USB…
Bus usb@2184000: USB EHCI 1.00
Bus usb@2184200: USB EHCI 1.00
scanning bus usb@2184000 for devices… 1 USB Device(s) found
scanning bus usb@2184200 for devices… 3 USB Device(s) found
scanning usb for storage devices… 1 Storage Device(s) found
scanning usb for ethernet devices… 0 Ethernet Device(s) found
Scanning usb 0:1…
583 bytes read in 27 ms (20.5 KiB/s)
21066988 bytes read in 837 ms (24 MiB/s)
Loading kernel from FIT Image at 12200000 …
Using ‘config@1’ configuration
Trying ‘kernel@1’ kernel subimage
Description: Linux Kernel 4.1
Type: Kernel Image
Compression: uncompressed
Data Start: 0x122000dc
Data Size: 5343856 Bytes = 5.1 MiB
Architecture: ARM
OS: Linux
Load Address: 0x11000000
Entry Point: 0x11000000
Hash algo: md5
Hash value: f03e68bd1f6f9aae8cfcab3e44848670
Verifying Hash Integrity … md5+ OK
Loading ramdisk from FIT Image at 12200000 …
Trying ‘ramdisk@1’ ramdisk subimage
Description: SquashFS RAMdisk
Type: RAMDisk Image
Data Start: 0x12718c34
Data Size: 15671296 Bytes = 14.9 MiB
Architecture: ARM
OS: Linux
Load Address: unavailable
Entry Point: unavailable
Hash algo: md5
Hash value: 25632f146bb649eb8883f5773ad2f4b0
Loading fdt from FIT Image at 12200000 …
Trying ‘fdt@1’ fdt subimage
Description: Apalis iMX6 Device Tree
Type: Flat Device Tree
Data Start: 0x1360acfc
Data Size: 50361 Bytes = 49.2 KiB
Architecture: ARM
Hash algo: md5
Hash value: 67b35a20ece1bd6c1c0639fed8dc7b47
Booting using the fdt blob at 0x1360acfc
Loading Kernel Image … OK
Loading Device Tree to 2fff0000, end 2ffff4b8 … OK
Starting kernel …
[ 0.139348] stmpe-i2c 2-0041: failed to read regs 0x0: -5
[ 1.274812] snvs-secvio 20cc000.caam-snvs: can’t get snvs clock
[ 1.283068] sgtl5000 2-000a: Error reading chip id -5
[ 1.400763] imx-sgtl5000 sound: ASoC: CODEC DAI sgtl5000 not registered
[ 1.407425] imx-sgtl5000 sound: snd_soc_register_card failed (-517)
[ 1.826534] imx6q-pcie 1ffc000.pcie: phy link never came up
[ 1.832161] imx6q-pcie 1ffc000.pcie: failed to initialize host
[ 1.840390] imx-sgtl5000 sound: ASoC: CODEC DAI sgtl5000 not registered
[ 1.847044] imx-sgtl5000 sound: snd_soc_register_card failed (-517)
[ 1.854921] imx-sgtl5000 sound: ASoC: CODEC DAI sgtl5000 not registered
[ 1.861583] imx-sgtl5000 sound: snd_soc_register_card failed (-517)
[ 2.127216] imx-sgtl5000 sound: ASoC: CODEC DAI sgtl5000 not registered
[ 2.133895] imx-sgtl5000 sound: snd_soc_register_card failed (-517)
Running /etc/rc.local…
Apalis-iMX6_ToradexEasyInstaller_1.8-20181019
[ 2.305431] imx-sgtl5000 sound: ASoC: CODEC DAI sgtl5000 not registered
[ 2.312080] imx-sgtl5000 sound: snd_soc_register_card failed (-517)
Welcome to Toradex Easy Installer
This is a Linux based installer for Toradex modules. Currently the
installer does not have a serial console interface. You can use the
Toradex Easy Installer through any of the available display interfaces
using USB mouse/keyboard or via network using VNC. Use:
ip addr show eth0
to display the Ethernet IP address or use USB RNDIS at IP 192.168.11.1.
/ # [ 3.289172] imx-sgtl5000 sound: ASoC: CODEC DAI sgtl5000 not registered
[ 3.295917] imx-sgtl5000 sound: snd_soc_register_card failed (-517)
[ 3.304826] sd 1:0:0:0: [sda] No Caching mode page found
[ 3.310192] sd 1:0:0:0: [sda] Assuming drive cache: write through
from the vncviewer (through debug USB cable) I can see the window but not through the HDMI output screen.
These involve only putting the module in recovery mode and loading the Toradex Easy Installer via USB, with the recovery-linux.sh or recovery-windows.bat scripts on the host machine.
Booting to USB with run bootcmd_usb0 is not needed here.
It is likely that you can only get an older version of the Toradex Easy Installer up because the installed image on the module has an older bootloader.
If the display output still does not work with a newer version of the Toradex Easy Installer, it may be that the HDMI video output is not functional.
However, please check if this is not a setup issue by using a Toradex carrier board.
I have checked with the carrier board setup (Ixora v1.1A) and in that case the display comes up. It seems some issue with the circuit of our board. It would be great if you can support with the hardware circuit. Can I directly send you the schematic of our board? Thanks
We have figured it out that it was hardware issue. The HDMI port does not generate the hardware interrupt. After changing the HDMI channels, we see the HDMI display. Thanks all of looking into this matter. Thread can be closed
