Verdin iMX8MP Q 4GB IT (V1.1B, PN 00631101, SN 08777772)
Verdin Development Board (V1.1F, PN 01561105, SN 12610832)
10.1 inch HDMI Touchscreen Monitor
USB mouse and keyboard
The HDMI Monitor is connected to Toradex DSI to HDMI Adapter. After power on the hardware for the first time, I installed Toradex OS Easy Pairing(7.7.0+build.40.modified.container (2026-07-16)). After the installation, I used the pairing code shown on the HDMI monitor for pairing. After the successful pairing, “Paired“ was shown on the HDMI monitor. But then, the display become blank/black even though I can still see the backlight.
As I am new to Toradex, please can you tell me if this is normal. If not, what can I do to recover the display.
Based on your setup and the issue you’re experiencing, the blank HDMI display after pairing is not normal and is likely related to a known issue with the Weston compositor on Torizon OS 7.x when using native HDMI on the Verdin Development Board.
Root Cause
When using the Toradex DSI to HDMI Adapter with the Verdin iMX8M Plus on Torizon OS 7.x, there’s a known bug in the Weston container that can cause the display to go blank after initialization(1).
Solution
You can resolve this issue using one of the following workarounds:
Workaround 1: Set WESTON_DISABLE_ATOMIC Environment Variable
Connect to your device via SSH and run the Weston container with the WESTON_DISABLE_ATOMIC=1 environment variable:
Hi bruno, I have duplicated post, can you follow up on another post as that post has more info from me: “HDMI display become blank after Torizon OS Easy Pairing installation and successful device pairing”? Thanks!
