Have 1/3 Flexcans on colibri imx8x working
Hi I have been working with getting CAN up and working on our IMX8QXP 2GB IT we have built our own development adapter and I currently have 1/3 CAN up and running but I need them all to function. We have triple and quadruple checked the wiring on our add-on board and it should be correct but I’m linking the schematics just in case.
  • Can1 pin 34, 35 “Linux CAN0? named Can1 in datasheet but CAN 1 in pintool”
    Gives no errors in my CAN validation tool but no traffic passes.
  • Can2 pin 38, 39 "Linux CAN1? named Can0 in datasheet but CAN 2 in pintool
    Gives errors on the CAN bus.
  • Can3 pin 26, 27 "Linux CAN2? named Can2 in datasheet but CAN 3 in pintool "
    Works flawlessly.
ifconfig gives the following information.
can0      Link encap:UNSPEC  HWaddr 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00 -00
          UP RUNNING NOARP  MTU:72  Metric:1
          RX packets:4 errors:0 dropped:0 overruns:0 frame:0
          TX packets:8 errors:0 dropped:2 overruns:0 carrier:2
          collisions:0 txqueuelen:1000
          RX bytes:32 (32.0 B)  TX bytes:8 (8.0 B)
          Interrupt:38
can1      Link encap:UNSPEC  HWaddr 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00 -00
          UP NOARP  MTU:16  Metric:1
          RX packets:3 errors:0 dropped:0 overruns:0 frame:0
          TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:24 (24.0 B)  TX bytes:0 (0.0 B)
          Interrupt:39
can2      Link encap:UNSPEC  HWaddr 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00 -00
          UP RUNNING NOARP  MTU:16  Metric:1
          RX packets:28 errors:0 dropped:0 overruns:0 frame:0
          TX packets:13 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:224 (224.0 B)  TX bytes:13 (13.0 B)
          Interrupt:40
I have linked our revised fsl-imx8qxp-colibri-eval-v3.dtsi we have done a kernel patch with the change and everything shows up in linux correctly as can be seen in the ifconfig.
I have disabled SPI / UART-A / UART-B / UART-C in order to not have any conflicts.
But I’ve discovered that only FlexCAN2 is in the datasheet 33/35 are both ALT0 and set to that as default.
While FlexCan1 *datasheet 19/21 are set to ALT2 while the default is set to ALT0/4.
Same thing on FlexCAN0 *datasheet 34/32 are set to ALT0 while the default is set to ALT4/0
Do i need to disable all other functions using the pins or are there some way to change the pins default function?
I would appreciate an example on how to disable the other functions if need be or how to set the pin default correctly.
//My Best Regards Martin S.J
Links: Viola adapter __ fsl-imx8qxp-colibri-eval-v3.dtsi
Greetings @Masj,
You shouldn’t need to do any re configuring of pins since the pinmuxing is already set up by default in the device tree, as seen here: imx8qxp-colibri.dtsi « freescale « dts « boot « arm64 « arch - linux-toradex.git - Linux kernel for Apalis, Colibri and Verdin modules
As for conflicting interfaces flexcan1 conflicts with UARTB and flexcan3 conflicts with UARTA. Flexcan2 doesn’t conflict with anything as far as I can tell. Other than that you’re adapter board doesn’t seem to complex so I doubt there’s any issues there as long as the wiring is correct.
So let’s try looking at your process. What I mean is what are you doing to enable, configure, and verify the CAN interfaces? Did you follow the steps as in this document: How to Use CAN on Torizon OS | Toradex Developer Center
Or did you do something different? Please give detailed steps in case we need to attempt to reproduce this on our side.
Ah okay you’re using our 4.0 Torizon then. Hmm we never did much testing/validation with this module and CAN on 4.0 Torizon. Just as a sanity check could you perform a quick test with your setup on 5.0 Torizon and see if there’s any differences?
I need some time to see whether the differences between 4.0 and 5.0 would even make a difference here.
Alright I have a change when using Torizon 5.0.0 i get physical Can 2 and 3 to work. In Linux they are refereed to as Can0 & Can2
I did a port of my configuration and the changes in the dtsi file are the same as the one above.
I did run a dmesg | grep flexcan and got the following message.
colibri-imx8x-v10b-06614244:~$ dmesg | grep flexcan
[  422.623602] flexcan 5a8e0000.can can1: bus-off
[  652.384734] flexcan 5a8e0000.can can1: bus-off
[  993.029455] flexcan 5a8e0000.can can1: bus-off
suggesting something is not working as intended.
when running ifconfig i get the following
can0: flags=193<UP,RUNNING,NOARP>  mtu 16  metric 1
        unspec 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00  txqueuelen 10  (UNSPEC)
        RX packets 26  bytes 159 (159.0 B)
        RX errors 0  dropped 0  overruns 0  frame 0
        TX packets 7  bytes 7 (7.0 B)
        TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
        device interrupt 64
can1: flags=193<UP,RUNNING,NOARP>  mtu 16  metric 1
        RX packets 9  bytes 72 (72.0 B)
        TX packets 0  bytes 0 (0.0 B)
        TX errors 0  dropped 3 overruns 0  carrier 3  collisions 0
        device interrupt 65
can2: flags=193<UP,RUNNING,NOARP>  mtu 16  metric 1
        RX packets 17  bytes 115 (115.0 B)
        TX packets 3  bytes 3 (3.0 B)
        device interrupt 66
But if I use cansend can1 500#00000000 i get the following
        device interrupt 64
can1: flags=129<UP,NOARP>  mtu 16  metric 1
        RX packets 12  bytes 96 (96.0 B)
        device interrupt 65
        device interrupt 66
It changes state which is the source for the bus-off state in dmesg.
so there is a difference and it works better 2/3 so far ^^
Can i provide any additional information?
It’s highly recommended to work with 5.X since that is the version the first production release of Torizon will be based off of. Also the screen output is a known issue since parallel RGB is off by default in 5.0 but can be re-enabled. Though we are going to re-enable it soon in the future. What are the other issues 5.X that don’t work for you?
I did a quick test myself on 5.X and strangely enough can1 works for me but can0 and can2 don’t. On my side I was able to set the bitrate for all 3 CAN interfaces and also enable them with ip link. But, once I sent a message with cansend, I get a similar bus-off message on can0/2. Is this similar to what you’re observing on your end as well?
I’m still investigating to see if this was some kind of user mis-configuration or perhaps a genuine bug.
Alright was worried that I would have to change the pins by myself so that’s a great relief.
I’ll ask an additional question before I go into the other stuff is the FLEXCAN name in the datasheet the same as the ones represented in ifconfig? It’s a bit confusing when the pintool and driver is based at 1 but not the datasheet ^^
My process is very close to yours I’m not deploying the tools in a container but instead i provide them as a part of my Yocto build which is based upon your latest 4.x.x Zeus@TorizonCore revision. Then I set up everything in the same way but with a bash script.
This is my core recipe:
SUMMARY = "TorizonCore"
DESCRIPTION = "TorizonCore Linux with no containers pre-provisioned."
require torizon-core-container-zeus.inc
KERNEL_MODULE_AUTOLOAD += "modprobe"
CORE_IMAGE_BASE_INSTALL_append = " \
    docker-ce \
    python3-docker-compose \
    docker-compose-up \
    iproute2 \
    bash \
    canutils \
    nano \
IMAGE_INSTALL_append = " \
    vmconfig \
    canconfig \
    accesspoint \
    vmautostart \
EXTRA_USERS_PARAMS += "\
usermod -a -G docker torizon; \
When validating the script i can see some mistakes, but I’ve tried to enable all adapters manually as in the link you posted so it should not mater How to Use CAN on Torizon OS | Toradex Developer Center.
We are using 250kbit/s instead of 500 but that’s the only difference that i can find.
ip link set can0 type can bitrate 250000
I’ll be using the “pin tool naming for the can devices bellow”
I have tried using using the can tools and they work flawlessly on can3 I have an external usb can-debugger that I’m able to both send and receive data with so i can verify that cansend and candump is working correctly. That device is giving an error when connecting can2 that’s why I thought there might be something conflicting on the pin like gpio. The can1 device gives no error on my usb debugger but no data enters or leaves.
Is there anything else i can provide you with?
I’ll add that there are many other things that do not work currently work when i use 5.x.x @ Torizon like no screen output and many other small things so I would like to focus on getting all can buses up and running on version 4.x.x
Firstly it’s a matter of time/cost we have everything except the final CAN buses working on Torizon version 4. When converting to version 5 both our current kiosk and the weston container stops working along with currently no display output which makes it hard to test and validate. It makes version 4 seem more stable currently and i have to motivate additional time spent on this part of the project.
Yes that is my observation as well setting bitrate works buses seems to be online/working. But once you try to send data over them with example cansend it changes state to bus-off but for me it only affects CAN1 with torizon 5 on IMX8X revision B and on torizon 4 it affected CAN 0 & 1
Hi @masj,
Just as an update, we are analyzing this issue carefully at Toradex in order to reproduce it and get to know workarounds or fixes.
The response from the middle to the end of December was delayed due to reduced personnel.
In the meantime, did you have any progress in this matter at your side?
André Curvello
Hi @Masj
I tested at my place all the three flexcan interfaces at same time. I haven’t see any errors.
Could you update to TDX Wayland with XWayland 5.1.0+build.4 (dunfell) \n \l and check if you still see any errors?
Thanks and best regards,
