What errors are you getting? I’ve had a quick look at the instructions and they should still be applicable for VS2013 + VS2015. Maybe I can work out what’s going on from the error messages.
Of source I can and will provide them. Let me start from the beginning:
code-when-not-linked: Start of the code (is from the GPIOdemo), I expect that it doesn’t work at this stage.
After-how-to-include-build: The error code that I get when building. If I remove that file (is “selected” in step 10) than it states that it cant find the next in that list and so on.
Other pics: My version of the guide pictures.
My project is storedas default by VS, thus in documents\projects\ConsoleApplication
In this folder is a new ConsoleApplication, and in that folder I have put the inc and libs folders (see picture stored).
It sure looks like it, not they way I left them when I posted this.
But after another 3 a 4 hours of tweaking, shifting and adjusting after uploading this post it didn’t gave any errors and would promptly work on the embedded system.
I don’t know what exactly the solution was after so many trial and errors. But I guess it had to do with that Visual Studio expects a certain order of declarations in the folder structure.
Thank you for your effort, appreciate your help very much.
