i have an app that is working on Linux and can work with Wayland.
Can I run this app inside a Container on TorizonCore and render the GUI via Wayland ?
Bg, Markus
Bg, Markus
Greetings @DrWenz,
This may depend on your exact GUI framework, but in general it should be possible. The idea would be you need to install your app and all it’s dependencies inside a container rather than on the host OS as you did before.
If you’re new to the container workflow, I’d suggest starting with our quickstart guide for TorizonCore: Quickstart Guide - Toradex
Then proceeding to our other TorizonCore based documentation, depending on what you’re trying to do next: Torizon | Toradex Developer Center
