Gtkterm no output
Hello, when I connect the board with the module to host computer(ubuntu) I get no output in gtkterm. what could be the problem?
Hi @valeandor and Welcome to the Toradex Community!
Could you provide the version of the hardware and software of your module?
Did you follow the getting started guide?
hi @jaski.tx and thank you !
Colibri vf 61
Iris carrier board
this is my hardware, and I did follow the instruction from the guide.
You are welcome.
Which UART converter are you using?
Could you share pictures of your setup showing all the necessary connections as Power, UART between carrier board and your host?
@jaski.tx its PL-2303. will attach pictures
[upload|i35MwcoxOMpsrwugMO9lJ5eQQd8=]
[upload|rIIgYA66i63QlxcHV0wbfd1FnXw=]
Hi @valeandor
Thanks for the pictures.
Unfortunately the connection on Iris carrier board side is wrong, the red cable showing Pin 1 should be on left side, near to the RJ45 Connector. Could you do this change and check if you see an output on the console?
