I get the following error from GTK when trying to get the screen resolution of my 1280x1024 panel:
(manager3:920): Gdk-CRITICAL **: 10:26:10.835: gdk_monitor_get_workarea: assertion 'GDK_IS_MONITOR (monitor)' failed
Gdk-Message: 10:26:11.019: Error 71 (Protocol error) dispatching to Wayland display.
I can see the mode is available using modetest, they also align to:
/sys/class/drm/card1-HDMI-A-1/modes
id encoder status name size (mm) modes encoders
148 147 connected HDMI-A-1 360x240 23 147
modes:
index name refresh (Hz) hdisp hss hse htot vdisp vss vse vtot
#0 1280x1024 60.02 1280 1328 1440 1688 1024 1025 1028 1066 108000 flags: phsync, pvsync; type: preferred, driver
#1 1920x1080 60.00 1920 2008 2052 2200 1080 1084 1089 1125 148500 flags: phsync, pvsync; type: driver
#2 1920x1080 59.94 1920 2008 2052 2200 1080 1084 1089 1125 148352 flags: phsync, pvsync; type: driver
#3 1920x1080 50.00 1920 2448 2492 2640 1080 1084 1089 1125 148500 flags: phsync, pvsync; type: driver
#4 1280x1024 75.02 1280 1296 1440 1688 1024 1025 1028 1066 135000 flags: phsync, pvsync; type: driver
#5 1360x768 60.02 1360 1424 1536 1792 768 771 777 795 85500 flags: phsync, pvsync; type: driver
#6 1280x720 60.00 1280 1390 1430 1650 720 725 730 750 74250 flags: phsync, pvsync; type: driver
#7 1280x720 59.94 1280 1390 1430 1650 720 725 730 750 74176 flags: phsync, pvsync; type: driver
#8 1280x720 50.00 1280 1720 1760 1980 720 725 730 750 74250 flags: phsync, pvsync; type: driver
#9 1024x768 75.03 1024 1040 1136 1312 768 769 772 800 78750 flags: phsync, pvsync; type: driver
#10 1024x768 70.07 1024 1048 1184 1328 768 771 777 806 75000 flags: nhsync, nvsync; type: driver
#11 1024x768 60.00 1024 1048 1184 1344 768 771 777 806 65000 flags: nhsync, nvsync; type: driver
#12 800x600 75.00 800 816 896 1056 600 601 604 625 49500 flags: phsync, pvsync; type: driver
#13 800x600 72.19 800 856 976 1040 600 637 643 666 50000 flags: phsync, pvsync; type: driver
#14 800x600 60.32 800 840 968 1056 600 601 605 628 40000 flags: phsync, pvsync; type: driver
#15 720x576 50.00 720 732 796 864 576 581 586 625 27000 flags: nhsync, nvsync; type: driver
#16 720x480 60.00 720 736 798 858 480 489 495 525 27027 flags: nhsync, nvsync; type: driver
#17 720x480 59.94 720 736 798 858 480 489 495 525 27000 flags: nhsync, nvsync; type: driver
#18 640x480 75.00 640 656 720 840 480 481 484 500 31500 flags: nhsync, nvsync; type: driver
#19 640x480 72.81 640 664 704 832 480 489 492 520 31500 flags: nhsync, nvsync; type: driver
#20 640x480 60.00 640 656 752 800 480 490 492 525 25200 flags: nhsync, nvsync; type: driver
#21 640x480 59.94 640 656 752 800 480 490 492 525 25175 flags: nhsync, nvsync; type: driver
#22 720x400 70.08 720 738 846 900 400 412 414 449 28320 flags: nhsync, pvsync; type: driver
I’ve tried a few weston output settings, the GDK error doesn’t occur when setting the display to 1920x1080, however this doesn’t give me the right resolution I need, and is a scaled resolution for the panel.
root@apalis-imx8-14903975:~# cat /etc/xdg/weston/weston.ini
[core]
#gbm-format=argb8888
idle-time=0
#use-g2d=1
xwayland=true
repaint-window=16
#enable-overlay-view=1
modules=screen-share.so
[shell]
size=1280x1024
panel-position=none
#background-color=0xff000000
background-image=/home/root/ArtworkWallpaperP.png
[libinput]
enable_tap=true
touchscreen_calibrator=true
calibration_helper=/usr/bin/toradex-save-touchscreen-calibration
[output]
name=HDMI-A-1
mode=1280x1024
#mode=preffered
#transform=rotate-90
#mode=current
#[output]
#name=HDMI-A-2
#mode=off
# WIDTHxHEIGHT Resolution size width and height in pixels
# off Disables the output
# preferred Uses the preferred mode
# current Uses the current crt controller mode
[screen-share]
command=/usr/bin/weston --backend=rdp-backend.so --shell=fullscreen-shell.so --no-clients-resize --rdp-tls-cert=/etc/freerdp/keys/server.crt --rdp-tls-key=/etc/freerdp/keys/server.key
I can set the resolution for the panel and launch another non-gtk application at the correct resolution (1280x1024), however the GTK application that launches this application fails.
To be clear, the resolution of this panel is 1280x1024, and I get no errors setting weston.ini to 1920x1080, however this gives me the wrong aspect for the panel.
Are there any other settings in weston.ini I should be using in order to aquire the correct settings for GTK to be able to obtain the display?
Thank you,
William
