Gstreamer1.0-libav not found in tdx-reference-multimedia-image
Salam ,
I need to run this command on apalis-tk1 terminal to open camera supported by an encoder
gst-launch-1.0 rtspsrc location=rtsp://192.168.1.195:554/h264 latency=10 ! decodebin ! autovideosink
an error occurred , said that
missing element: h.264 (base line profile) decoder
your Gstremer installation is missing a plug-in
I did not install gstreamer it came by default with multimedia image.
how can I install gstreamer1.0-libav plug-in in wayland terminal since i have no yam, apt-get … ?
is there any other soltion that i can come over this problem ?
The following steps show how to install gstreamer1.0-libav into a rootfs image.
  1. Add the following lines into the configuration file conf/local.conf.
    IMAGE_INSTALL_append = " gstreamer1.0-libav"
    LICENSE_FLAGS_WHITELIST = “commercial”
  2. Build gstreamer1.0-libav.
    $ bitbake gstreamer1.0-libav
  3. Build the rootfs image.
    $ bitbake
    $ <image_name>
HI @rama.aloufee
Unfortunately we only support Kernel 5.x and higher on the current versions of Apalis iMX8QM.
I see that there are some answers on the NXP community. What exactly is your issue?
my issue : how to install gstreamer1.0-libav to my multimedia image
since multimedia image has gstreamer but not all the plugins are there
the answer was by append gstreamer1.0-libav to my multimedia image
then re-bitbake
OK, is the issue solved now?
yes it is solved now
i have mentioned that already
then re-bitbake
Perfect that the issue is solved.
Thanks for the feedback.
