I need to use the gstreamer plugin rtmp which provides in particular “rtmpsink” but I am unable to find it in any plugin package, of both gstreamer1.0 ad 0.10. it should be in “bad plugins” any advice for installing it on our Apalis T30 BSP2.6?
The gstreamer bad plugin recipe in OpenEmbedded does not enable rtmp build by default. The recipe does however have a package configuration option available. See here. To enable it, add the following to ~oe-core/build/conf/local.conf
I tested the above build on our latest OE morty branch but the same should work with OE jethro. To add it to the image itself, add gst-plugins-bad-rtmp to the image recipe you are using.
