Dear community,
We need a system with multimedia support for recording video and play/seek video (h264). Our system is based on 3.14.28 linux and jethro flavour of Yocto FSL.
Could you please explain the difference / utility of these different package for imx6 board ?
gst1.0-fsl-plugin
imx-gst1.0-plugin,
gstreamer1.0-plugins-imx
imx-vpu
firmware-imx \
Do I need more ? Which ipu or g2d sink I must use for this purpose ?
Best Regards, Vincent
Hi @VincentB
Could you provide the hardware version of your module?
What is your application?
We are not supporting any kernel lower than version 4.9 for iMX6.
Hi @jaski.tx,
The hardware is based on an Apalis imx6 module. I know that this kernel version is old but so our device. The application provides to user the possibility to play videos recorded on the system.
Best regards, Vincent
Hi @VincentB
You might have a look here.
Further, you might check with gst-inspect*, which source and sink might be the best for you.
