I produce a mpegts stream with the below command and the output stream is around 1500 kbit/s. I would expect it to be around 700kbits since I give the “bitrate=700” option.
I tried removing the “mpegtsmux” option but the output stream dropped to 1300 kbit/s
Can you please guide me about what I am doing wrong?
We are using a (800 TVL) PAL (720 x 576) camera. There is an ADV7280 which converts incoming analog video to paralell. Incoming parallel video data is then H264 encoded, serialized and sent over UART. For the encoding we currently use the command in the first post.
For FPS, VLC shows 25 fps, we use the default settings of ADV7280 driver
We are using a colibri imx6 solo 512 MB IT module with a custom baseboard which has an ADV7280
Here are the software versions
root@colibri-imx6:~# gst-launch-1.0 --version
gst-launch-1.0 version 1.12.2
GStreamer 1.12.2
root@colibri-imx6:~# gst-inspect-1.0 imxv4l2src
====== IMXV4L2SRC: 4.3.1 build on Jul 3 2018 14:07:07. ======
root@colibri-imx6:~# gst-inspect-1.0 imxvpuenc_h264
Factory Details:
Rank primary + 1 (257)
Long-name Freescale VPU h.264 video encoder
Klass Codec/Encoder/Video
Description hardware-accelerated h.264 video encoding using the Freescale VPU engine
Author Carlos Rafael Giani <dv@pseudoterminal.org>
Plugin Details:
Name imxvpu
Description video en- and decoder elements using the Freescale i.MX VPU
Filename /usr/lib/gstreamer-1.0/libgstimxvpu.so
Version 0.13.0
License LGPL
Source module gstreamer-imx
Binary package Unknown package release
Origin URL Unknown package origin
Thanks for these Information. Actually it will be helpful to have the Linux Kernel Version ( uname ). Did you try setting a different bitrate? Maybe also higher than 1500?
Additionally can you read our developer article about Video in Linux?
Thanks for the video in linux link. The warning about bitrate option seems to suit our case.
However “imxvpuenc_h264” doesn’t seem to have these extra options.
Element Properties:
name : The name of the object
flags: readable, writable
String. Default: "imxvpuencoderh264-0"
parent : The parent of the object
Object of type "GstObject"
drop : Drop frames
Boolean. Default: false
gop-size : How many frames a group-of-picture shall contain
Unsigned Integer. Range: 0 - 32767 Default: 16
bitrate : Bitrate to use, in kbps (0 = no bitrate control; constant quality mode is used)
Unsigned Integer. Range: 0 - 4294967295 Default: 0
slice-size : Maximum slice size (0 = unlimited, <0 in MB, >0 in bits)
Integer. Range: -2147483648 - 2147483647 Default: 0
intra-refresh : Minimum number of MBs to encode as intra MB
me-search-range : Search range for motion estimation
Enum "ImxVpuEncMESearchRanges" Default: 0, "256x128"
(0): 256x128 - 256x128 blocks
(1): 128x64 - 128x64 blocks
(2): 64x32 - 64x32 blocks
(3): 32x32 - 32x32 blocks
quant-param : Constant quantization quality parameter (ignored if bitrate is set to a nonzero value)
Unsigned Integer. Range: 0 - 51 Default: 0
idr-interval : Interval between IDR frames
Am I missing something?
Also below are the uname and 1600 kbit/second encoding outputs. Again, imxvpuenc_h264 seems to produce double the expected bitrate
didn’t check the frame rate correctly.
ADV7280 was outputting 50 fps. Dropped half of it and the bitrate is in accordance with the input target bitrate
