Hi Henrique
Thank you for the informations.
Module we use is : Col iMX7D 512MB V1.1D.
OS is built by us (Yocto)
The Gstreamer command that is used is : gst-launch-1.0 uridecodebin uri=file:///home/root/audio.wav ! audioconvert ! audio/x-raw,channels=1 ! audioresample ! volume name="cs4000_volume" ! tee name=tee0 ! queue max-size-buffers=1 max-size-bytes=0 max-size-time=0 tee0. ! queue max-size-buffers=1 max-size-bytes=0 max-size-time=0 ! jackaudiosink port-pattern=system:playback_1
cat /etc/issue send : OpenEmbedded nodistro.0 \n \l
/etc/os-release doesn’t exist.
gst-inspect command is not available
Complementary information on the error message is :
read(5, “W”, 1) = 1
futex(0xdb048c, FUTEX_WAKE_PRIVATE, 1) = 0
write(14, “\1\0\0\0\0\0\0\0”, 8) = 8
futex(0xed2a24, FUTEX_WAKE_PRIVATE, 2147483647) = 0
write(2, “ERROR: from element /GstPipeline”…, 88ERROR: from element /GstPipeline:pipeline0/GstQueue:queue0: Internal data stream error.
) = 88
write(2, “Additional debug info:\n../../../”…, 197Additional debug info:
../../../gstreamer-1.16.2/plugins/elements/gstqueue.c(988): gst_queue_handle_sink_event (): /GstPipeline:pipeline0/GstQueue:queue0:
streaming stopped, reason not-linked (-1)
) = 197
rt_sigaction(SIGINT, {sa_handler=SIG_DFL, sa_mask=, sa_flags=SA_RESTORER, sa_restorer=0x48b2b241}, NULL, 8) = 0
rt_sigaction(SIGHUP, {sa_handler=SIG_DFL, sa_mask=, sa_flags=SA_RESTORER, sa_restorer=0x48b2b241}, NULL, 8) = 0
write(1, “Execution ended after 0:00:14.38”…, 40Execution ended after 0:00:14.387400750
) = 40
write(1, “Setting pipeline to PAUSED …\n”, 31Setting pipeline to PAUSED …
) = 31
futex(0xeb40d0, FUTEX_WAKE_PRIVATE, 2147483647) = 0
Thank you
