Hi all,
I stumbled onto a new challenge…
On the M4 of my Colibri i.MX4D, I am using timer GPT4 to toggle an I/O pin (GPT4.COMPARE3) with a frequency that is derived from an external 4MHz clock (on the GPT4.CLK pin). There are no GPT or I/O interrupts associated with this setup. After initialization, GPT4 is “kept alone”.
When running the M4 without Linux (halted in U-Boot), everything works fine and the GPT4.COMPARE3 output toggles at the frequency I want (e.g. 100kHz).
Now, when I start Linux (boot
command on U-Boot prompt), things get weird:
- There are periods in which the output signal stops. This can be several seconds. Linux boots and the console works fine.
In this scenario, the M4 does not access any of the GPT4 registers after the initialization that was done before booting Linux - If, during the boot, the M4 accesses the CR register of GPT4, the Linux boot never finishes and generally ends with a system reset. (The M4 accesses GPT4->CR when I type a character on the M4 console)
To me, this looks like a conflict between Linux and the M4 concerning GPT4. The question is how exactly.
On the Linux side:
- I have modified the device tree, such that I explicitly disable
gpt4
on the highest level .dts file (I’m using Torizon 5.6 and Torizon Builder to incorporate the DT changes).
Note that this is not really necessary since it is already disabled inimx7s.dtsi
On the M4 side
- I have configured the gpio mux for the two GPT4 pins
- obtained exclusive access to GPT4 (“GPTB” in the board.h defines):
RDC_SetPdapAccess( RDC, BOARD_GPTB_RDC_PDAP, 3 << (BOARD_DOMAIN_ID * 2), false, false);
- I also configure the clocks for the GPT4 peripheral (not to confuse with the external clock source on the GPT4.CLK input)
//--- Enable Sys PLL PFD0 for GPTB peripheral clock (this is NOT the counter source !)
CCM_ControlGate( CCM, ccmPllGatePfd0, ccmClockNeededRunWait);
//--- Select GPTB peripheral root clock source: derived from PLL PFD0
CCM_UpdateRoot ( CCM, BOARD_GPTB_CCM_ROOT, ccmRootmuxGptSysPllPfd0, 0, 0);
CCM_EnableRoot ( CCM, BOARD_GPTB_CCM_ROOT);
CCM_ControlGate( CCM, BOARD_GPTB_CCM_CCGR, ccmClockNeededRun);
To summarize:
- Linux does something that occasionally stops output on the GPT compare output, without changing anything (it keeps the same frequency)
=> Perhaps something with the peripheral clock tree ?? - When the M4 tries to access a GPT4 register while Linux is booting or after it, then both Linux and the M4 are stuck and after a while, the module reboots
Does anyone have an idea of what may be going on ?
Thanks for your precious help, as always.
Jeroen
