Hello! Thank you for reaching out with your question.
The behavior you’re observing likely means that GPIO5_IO12 (SODIMM 116) is not properly configured as a GPIO in the device tree. Even though the gpioset and gpioinfo tools report the direction and value changes, the pin will not respond at the hardware level unless it is correctly muxed for GPIO use in the device tree.
Immediate Troubleshooting Steps
Since you mentioned you’re not set up to change device trees, your quickest option is to use a different GPIO pin that is already configured for GPIO use.
You can check which GPIO pins are available and ready by running:
gpioinfo | grep -e "SODIMM" -e "MXM3"
This command will help you identify which pins are available and already properly muxed for GPIO usage. Try using one of those pins for your enable signal.
References:
Why is Device Tree Change Needed?
The pin remains LOW because, by default, it may be set up for another hardware function, not pure GPIO. In such a case, Linux userspace tools will not generate errors but also won’t affect the pin state.
“it is important to make sure that the pin is actually muxed as a GPIO in the device-tree or platform data. Failing to do so will not give any error. The pin will simply report 0 if configured as an input and not react to any state change if configured as an output”
— Toradex GPIO Linux Documentation
If You Must Use SODIMM 116
If you absolutely need to use SODIMM 116 (GPIO5_IO12), you will need to create a device tree overlay that muxes the pin to GPIO mode. Overlays allow making such changes without building a custom kernel. Toradex provides documentation that can help you get started with this process if you decide to set up for device tree changes in the future.
Summary
- Quick workaround: Use a different GPIO pin already configured and available.
- Permanent solution for this pin: Create a device tree overlay to properly configure SODIMM 116 as GPIO (recommended for production).
Further reading and references:
Let me know if you need help identifying possible alternative pins or if you’d like more step-by-step guidance on overlays!
