I’ve a test program running well in FreeRTOS using GPIO and SPI, but without linux running on the A7 cores.
I need to run also Linux on the two A7 cores, but in the FreeRTOS program I’ve used GPIO02_22 (SODIMM 127) and GPIO02_IO26 (SODIMM 133).
To avoid linux blocking, I need to disable the entire GPIO2 bank in the linux device tree.
But in the DT we have:
&iomuxc {
pinctrl-names = "default";
pinctrl-0 = <&pinctrl_gpio1 &pinctrl_gpio2 &pinctrl_gpio3 &pinctrl_gpio4
&pinctrl_gpio5 &pinctrl_gpio6 &pinctrl_gpio7>;
pinctrl_gpio1: gpio1-grp {
fsl,pins = <
MX7D_PAD_SAI1_RX_SYNC__GPIO6_IO16 0x14 /* SODIMM 77 */
MX7D_PAD_EPDC_DATA09__GPIO2_IO9 0x14 /* SODIMM 89 */
MX7D_PAD_EPDC_DATA08__GPIO2_IO8 0x74 /* SODIMM 91 */
MX7D_PAD_LCD_RESET__GPIO3_IO4 0x14 /* SODIMM 93 */
MX7D_PAD_EPDC_DATA13__GPIO2_IO13 0x14 /* SODIMM 95 */
MX7D_PAD_ENET1_RGMII_TXC__GPIO7_IO11 0x14 /* SODIMM 99 */
MX7D_PAD_EPDC_DATA10__GPIO2_IO10 0x74 /* SODIMM 105 */
MX7D_PAD_EPDC_DATA00__GPIO2_IO0 0x14 /* SODIMM 111 */
MX7D_PAD_EPDC_DATA01__GPIO2_IO1 0x14 /* SODIMM 113 */
MX7D_PAD_EPDC_DATA02__GPIO2_IO2 0x14 /* SODIMM 115 */
MX7D_PAD_EPDC_DATA03__GPIO2_IO3 0x14 /* SODIMM 117 */
MX7D_PAD_EPDC_DATA04__GPIO2_IO4 0x14 /* SODIMM 119 */
MX7D_PAD_EPDC_DATA05__GPIO2_IO5 0x14 /* SODIMM 121 */
MX7D_PAD_EPDC_DATA06__GPIO2_IO6 0x14 /* SODIMM 123 */
MX7D_PAD_EPDC_DATA07__GPIO2_IO7 0x14 /* SODIMM 125 */
MX7D_PAD_EPDC_SDCE2__GPIO2_IO22 0x14 /* SODIMM 127 */
MX7D_PAD_UART3_RTS_B__GPIO4_IO6 0x14 /* SODIMM 131 */
MX7D_PAD_EPDC_GDRL__GPIO2_IO26 0x14 /* SODIMM 133 */
MX7D_PAD_SAI1_RX_DATA__GPIO6_IO12 0x14 /* SODIMM 169 */
MX7D_PAD_SAI1_RX_BCLK__GPIO6_IO17 0x14 /* SODIMM 24 */
MX7D_PAD_SD2_DATA2__GPIO5_IO16 0x14 /* SODIMM 100 */
MX7D_PAD_SD2_DATA3__GPIO5_IO17 0x14 /* SODIMM 102 */
MX7D_PAD_EPDC_GDSP__GPIO2_IO27 0x14 /* SODIMM 104 */
MX7D_PAD_EPDC_BDR1__GPIO2_IO29 0x14 /* SODIMM 110 */
MX7D_PAD_EPDC_PWR_COM__GPIO2_IO30 0x14 /* SODIMM 112 */
MX7D_PAD_EPDC_SDCLK__GPIO2_IO16 0x14 /* SODIMM 114 */
MX7D_PAD_EPDC_SDLE__GPIO2_IO17 0x14 /* SODIMM 116 */
MX7D_PAD_EPDC_SDOE__GPIO2_IO18 0x14 /* SODIMM 118 */
MX7D_PAD_EPDC_SDSHR__GPIO2_IO19 0x14 /* SODIMM 120 */
MX7D_PAD_EPDC_SDCE0__GPIO2_IO20 0x14 /* SODIMM 122 */
MX7D_PAD_EPDC_SDCE1__GPIO2_IO21 0x14 /* SODIMM 124 */
MX7D_PAD_EPDC_DATA14__GPIO2_IO14 0x14 /* SODIMM 126 */
MX7D_PAD_EPDC_PWR_STAT__GPIO2_IO31 0x14 /* SODIMM 128 */
MX7D_PAD_EPDC_SDCE3__GPIO2_IO23 0x14 /* SODIMM 130 */
MX7D_PAD_EPDC_GDCLK__GPIO2_IO24 0x14 /* SODIMM 132 */
MX7D_PAD_EPDC_GDOE__GPIO2_IO25 0x14 /* SODIMM 134 */
MX7D_PAD_EPDC_DATA12__GPIO2_IO12 0x14 /* SODIMM 150 */
MX7D_PAD_EPDC_DATA11__GPIO2_IO11 0x14 /* SODIMM 152 */
MX7D_PAD_SD2_CLK__GPIO5_IO12 0x14 /* SODIMM 184 */
MX7D_PAD_SD2_CMD__GPIO5_IO13 0x14 /* SODIMM 186 */
I suppose the kernel doesn’t work well without this gpio …
Do you have some suggestion to solve the conflict? (like using other gpio?
SPDIF, audio and input camera are not used in my applications).
Thank you
