Hi @leighjboyd ,
I have some good news for you: based on the steps given by @jeremias.tx I was able to make both SODIMM 113 and 123 function correctly as GPIO. I made some tests using gpioset and your ToggleGPIO() and everything works: both pins can be set and I can read the correct value of SODIMM 123.
Here is what I’ve done in the device tree:
- Disabled
weimas that uses the pins we need; - Created a custom pinctrl group with both pins in it set as GPIO;
- In
iomuxcI added this group topinctrl-0, a property that wasn’t declared before; - I also created
pinctrl-namesinsideiomuxc.
All these changes are in the attached Device Tree source file. It is a copy of imx6dl-colibri-eval-v3.dts albeit with the above modifications. You can use TorizonCore Builder to create a custom image that uses this .dts file.
Let me know if that works for you.
Lucas Akira
