I use bootloader like:
Toradex Bootloader 2.0 BETA 4 for Tegra Built Jan 4 2017
Press [SPACE] to enter Bootloader Menu
BootLoader Configuration:
C) Clear Flash Registry
X) Enter CommandPrompt Mode
D) Download image to RAM now
F) Download image to FLASH now
L) Launch existing flash resident image now
Enter your selection: x
** >set gpio **
gpio.bootconf (Boot GPIO settings. Do not remove default config. (Max 1536 chars)):
'[gpio_168] altfn=-1 [gpio_169] altfn=-1 [gpio_170] altfn=-1 [gpio_171] altfn=-1 pull=down [gpio_172] altfn=-1 [gpio_173] altfn=-1 [gpio_174] altfn=-1 [gpio_175] altfn=-1 '
- I know I should keep existing string, but for my tests it should be irrelevent, yes? *
Next I try to change my real T20 GPIO (DIMM_97;L3;VI_D5) settings, forcing OUT-level 1:
set gpio.bootconf="[gpio_97] altfn=-1 outmode=std dir=out lvl=1 pull=up "
saveconfig gpio
IMPORTANT: Here I had to type the string using “double-quotes”, while report above was ‘single-quoted’!)
Now, I boot WinCE7 and use the GPIOConfig tool to check state, but nothing has changed. (also checked pin voltage, nothing)
Is the string syntax correct? any other requirements to activate gpio.bootconf?
Thanks!
