GPIO access from M4 on MX7
I want to write a little program for the M4 to toggle a GPIO with a specific (selectable) frequency. The manual points out that i should disable a whole GPIO bank in the device tree to give the M4 full access. Do i always need to do so or just when i want to use interrupt mode? Maybe there is a little demo which works out of the box for my setup? I am using a MX7D on a Viola board.
Thanks!
Or maybe there is a way to disable a gpio bank by a kernel boot argument? Like with the uarts?
Yes the u-boot fdt_fixup environment variable can be set to disable the gpio node as well. Something like below should disable first gpio bank.
Colibri iMX7 # setenv fdt_fixup 'fdt addr ${fdt_addr_r} && fdt rm /soc/aips-bus@30000000/gpio@30200000'
Also see below for an idea of how you may traverse the tree from u-boot.
Colibri iMX7 # ubi part ubi
ubi0: default fastmap pool size: 200
ubi0: default fastmap WL pool size: 100
ubi0: attaching mtd1
ubi0: attached by fastmap
ubi0: fastmap pool size: 200
ubi0: fastmap WL pool size: 100
ubi0: attached mtd1 (name "mtd=4", size 508 MiB)
ubi0: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
ubi0: min./max. I/O unit sizes: 2048/2048, sub-page size 2048
ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
ubi0: good PEBs: 4060, bad PEBs: 4, corrupted PEBs: 0
ubi0: user volume: 4, internal volumes: 1, max. volumes count: 128
ubi0: max/mean erase counter: 92/20, WL threshold: 4096, image sequence number: 0
ubi0: available PEBs: 0, total reserved PEBs: 4060, PEBs reserved for bad PEB handling: 76
Colibri iMX7 # ubi read ${fdt_addr_r} dtb
Read 0 bytes from volume dtb to 82000000
No size specified -> Using max size (43596)
Colibri iMX7 # fdt addr ${fdt_addr_r}
Colibri iMX7 # fdt list
        #address-cells = <0x00000001>;
        #size-cells = <0x00000001>;
        model = "Toradex Colibri iMX7D on Colibri Evaluation Board V3";
        compatible = "toradex,colibri_imx7d-eval", "toradex,colibri_imx7d", "fsl,imx7d";
        chosen {
        aliases {
        memory {
        cpus {
        interrupt-controller@31001000 {
        clocks {
        timer {
        etr@0,30086000 {
        tpiu@0,30087000 {
        replicator {
        etf@0,30084000 {
        funnel@1,30083000 {
        funnel@0,30041000 {
        etm@0,3007c000 {
        reserved-memory {
        soc {
        etm@1,3007d000 {
        backlight {
        pxp_v4l2_out {
        regulator-module-3v3 {
        regulator-module-3v3-avdd {
        sound {
        tcml@007f8000 {
        gpio-keys {
        usbc_det {
        regulator-3v3 {
        regulator-5v0 {
        regulator-usbh-vbus {
Colibri iMX7 # fdt list /soc/
soc {
        compatible = "simple-bus";
        interrupt-parent = <0x00000011>;
        ranges;
        busfreq {
        caam-sm@00100000 {
        caam_secvio {
        pmu {
        sram@00900000 {
        sram@901000 {
        sram@00180000 {
        sram-mf@00900000 {
        dma-apbh@33000000 {
        gpmi-nand@33002000 {
        aips-bus@30000000 {
        aips-bus@30400000 {
        aips-bus@30800000 {
        pcie@0x33800000 {
Colibri iMX7 # fdt list /soc/aips-bus@30000000/
aips-bus@30000000 {
        compatible = "fsl,aips-bus", "simple-bus";
        reg = <0x30000000 0x00400000>;
        ranges;
        gpio@30200000 {
        gpio@30210000 {
        gpio@30220000 {
        gpio@30230000 {
        gpio@30240000 {
        gpio@30250000 {
        gpio@30260000 {
        lpsr-gpr@30270000 {
        wdog@30280000 {
        wdog@30290000 {
        wdog@302a0000 {
        wdog@302b0000 {
        iomuxc-lpsr@302c0000 {
        gpt@302d0000 {
        gpt@302e0000 {
        gpt@302f0000 {
        gpt@30300000 {
        kpp@30320000 {
        iomuxc@30330000 {
        iomuxc-gpr@30340000 {
        mqs {
        ocotp-ctrl@30350000 {
        anatop@30360000 {
        tempmon {
        caam-snvs@30370000 {
        snvs@30370000 {
        ccm@30380000 {
        src@30390000 {
        gpc@303a0000 {
Colibri iMX7 # fdt list /soc/aips-bus@30000000/gpio@30200000
gpio@30200000 {
        compatible = "fsl,imx7d-gpio", "fsl,imx35-gpio";
        reg = <0x30200000 0x00010000>;
        interrupts = <0x00000000 0x00000040 0x00000004 0x00000000 0x00000041 0x00000004>;
        gpio-controller;
        #gpio-cells = <0x00000002>;
        interrupt-controller;
        #interrupt-cells = <0x00000002>;
        linux,phandle = <0x00000040>;
Thank you for this valuable information. Is the first gpio bank a good choice to put it away from the A7/Linux? Is there any good document which shows which pins of which bank are used for what?
Sorry but we don’t have any document with such information collated in a single place. You can find the pins configured as gpios by default as per the Colibri standard in Colibri iMX7 datasheet.
Ok. I already figured out that i want to use gpio bank 4 exclusivly for M4. IMHO the pins 11-15 on the Viola board connector X9 are all configured as gpios and belong to bank 4. So, where can i find mapping information like: gpio bank 1 == gpio@30200000… ?
This can be found from the iMX7 datasheet, device tree or explored in u-boot as described earlier.
I’m in the same situation. Actually this thread pointed me to this issue. So I hope it is okay to ask some additional questions.
While running Linux I can run the following command to see which GPIOs are in use:
cat /sys/kernel/debug/gpio
On my Viola board I get this output:
GPIOs 0-31, platform/30200000.gpio, 30200000.gpio:
 gpio-0   (cd                  ) in  lo
GPIOs 32-63, platform/30210000.gpio, 30210000.gpio:
GPIOs 64-95, platform/30220000.gpio, 30220000.gpio:
GPIOs 96-127, platform/30230000.gpio, 30230000.gpio:
 gpio-103 (VCC_USB[1-4]        ) out lo
GPIOs 128-159, platform/30240000.gpio, 30240000.gpio:
GPIOs 160-191, platform/30250000.gpio, 30250000.gpio:
GPIOs 192-223, platform/30260000.gpio, 30260000.gpio:
 gpio-194 (?                   ) out lo
 gpio-195 (Power-Key           ) in  hi
 gpio-206 (id                  ) in  lo
(I have added a gpio-poweroff(?) and a gpio-key(Power-Key).)
This means I can’t use any GPIO1_IOxx, GPIO4_IOxx and GPIO7_IOxx pins.
Is this correct?
This behavior becomes only an issue, when I want to use an GPIO as an interrupt source for the M4?
In my current configuration I could still use GPIO7_IO1 as an ‘regular’ input and/or output for the M4 without problems?
Jochen Loeser
@qojote you are mention “..GPIO with a specific (selectable) frequency..”. You may able to use a PWM unit for such a task. Then you would have both cores for other tasks still available.
Any GPIO already used by a driver cannot be used on Linux unless you either disable the driver or change the pin multiplexing. For example, GPIO1_IO01 is used for wakeup from suspend and GPIO7_IO14 is used for USB client detect. It would be recommended that a GPIO bank used on the M4 side be not used on the Linux side or vice versa.
