I am using the VerdiniMX8Mplus with Dahlia. Trying to use pin 30 on X20 connector as GP input.
As per the table 5-4 dedicated GPIO signals in datasheet for Verdin, I have the following information.
212 GPIO_4 GPIO1_IO06 GPIO1_IO6
So this GPI appears to line up with “gpiochip1” and pin 6.
I am using the code as per this link to read the GP input.
However, I am getting a -1 i.e. I am not getting any value received.
I have also used the input to this pin as 1.8SW output from X20 pin 26 on the same connector, to see if the GP input reads a 1 , however I am not getting the right output.
Software that I am using on the board is as follows:
Linux verdin-imx8mp-07331171 5.15.77-6.1.0-devel+git.a8d2c55c6ae7 #1-TorizonCore SMP PREEMPT Wed Nov 30 08:37:42 UTC 2022 aarch64 aarch64 aarch64 GNU/Linux
You would be correct when thinking about how the datasheet and device tree lists this pin. However, in Linux the numbering for gpiochip* starts at 0 not 1. This means in software the gpiochip you want is 1 less than what you think. You can see this via the output from gpioinfo:
gpiochip0 - 32 lines:
line 0: "SODIMM_206" unused input active-high
line 1: "SODIMM_208" unused input active-high
line 2: unnamed unused input active-high
line 3: unnamed "interrupt" input active-high [used]
line 4: unnamed unused input active-high
line 5: "SODIMM_210" unused input active-high
line 6: "SODIMM_212" unused input active-high
line 7: "SODIMM_216" unused input active-high
line 8: "SODIMM_218" unused input active-high
line 9: unnamed unused output active-high
line 10: unnamed "interrupt" input active-high [used]
line 11: "SODIMM_16" unused input active-high
line 12: "SODIMM_155" unused input active-high
line 13: "SODIMM_157" unused input active-high
line 14: "SODIMM_185" unused input active-high
line 15: "SODIMM_91" unused input active-high
line 16: unnamed unused input active-high
line 17: unnamed unused input active-high
line 18: unnamed unused input active-high
line 19: unnamed unused input active-high
line 20: unnamed unused input active-high
line 21: unnamed unused input active-high
line 22: unnamed unused input active-high
line 23: unnamed unused input active-high
line 24: unnamed unused input active-high
line 25: unnamed unused input active-high
line 26: unnamed unused input active-high
line 27: unnamed unused input active-high
line 28: unnamed unused input active-high
line 29: unnamed unused input active-high
line 30: unnamed unused input active-high
line 31: unnamed unused input active-high
As seen above even though in the datasheet this pin is listed under gpiochip/bank 1 in software it’s actually under gpiochip0.
Tried changing to “gpiochip0” but still pin reads -1. Got the same issue with the remaining gpios noted ie. gpiochip2, gpiochip3, gpiochip4 and gpiochip5.
I am wondering if this pin has been defined as an alternate function.
I also tried the other pin 5 apart from pin 6 on X20 connector, but get the same output.
I have also tried using gpioinfo on SSH terminal for the Verdin Dahlia, but get a command not found error. Tried with both the software versions 5.7.0 and 6.1.0 supported currently on Verdin iMX8Mplus.
@jeremias.tx and I did some testing. Would you mind trying to rebuild the docker image with some additional build arguments. We found the README guides need updating as well.
As far as I can tell SODIMM pin 212 is defined with the GPIO function by default.
The gpioinfo tool and other libgpiod related tools are only available in a container where these tools are installed. These tools are not available on TorizonCore itself.
