OS: linux :: x64 :: WSL 2
Distro: Ubuntu 22.04.3 LTS
Extension activation logs:
Activating Torizon IDE ...
Telemetry is enabled
Extension collects completely anonymous telemetry data about templates usage. Participation in this anonymous program is optional, and you may opt-out if you'd not like to share any information. Check: https://github.com/toradex/torizon-experimental-torizon-ide-v2-docs/blob/main/USAGE-DATA.md#opt-out
Telemetry allows us to accurately gauge templates usage. This data will help us to focus better on the most used templates, adding new features and putting effort in the right place.
Resolving host IP address ...
Host IP address OK
Docker installed OK
Docker running OK
Docker compose OK
PowerShell OK
git OK
dig OK
avahi-resolve OK
nmap OK
iputils-ping OK
file OK
sshpass OK
net-tools OK
Cloning project templates
Project templates clone OK
Project templates fetched OK
Checkout templates repo to v2.3.2 OK
[01-09 11:46:00.02] Checking connected devices ...
[01-09 11:46:00.03] Scanning Torizon devices ...
Configuring debug id_rsa ...
Debug id_rsa OK
Torizon IDE extension activated
Checking host ip sanity ...
Host ip is OK
Device 200.235.64.54 set as Docker Host
Debian stable packages list load OK
ERROR :: build-debug-amd64-local failed with exit code 2
Tasks logs:
Container Runtime: docker
Run Arguments: --rm --privileged torizon/binfmt
Container Name: binfmt
Error response from daemon: No such container: binfmt
Container does not exists. Starting ...
* Terminal will be reused by tasks, press any key to close it.
* Executing task: cmake -DCMAKE_BUILD_TYPE=Debug -B/home/andre/Braile2/build-local
-- The CXX compiler identification is GNU 11.4.0
-- The C compiler identification is GNU 11.4.0
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Check for working CXX compiler: /usr/bin/c++ - skipped
-- Detecting CXX compile features
-- Detecting CXX compile features - done
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Check for working C compiler: /usr/bin/cc - skipped
-- Detecting C compile features
-- Detecting C compile features - done
-- Configuring done
-- Generating done
-- Build files have been written to: /home/andre/Braile2/build-local
* Executing task: cmake --build /home/andre/Braile2/build-local
[ 50%] Building CXX object CMakeFiles/Braile2.dir/src/main.cpp.o
[100%] Linking CXX executable debug/Braile2
/usr/bin/ld: CMakeFiles/Braile2.dir/src/main.cpp.o: warning: relocation against `_ZTVN2sf11CircleShapeE' in read-only section `.text._ZN2sf11CircleShapeD2Ev[_ZN2sf11CircleShapeD5Ev]'
/usr/bin/ld: CMakeFiles/Braile2.dir/src/main.cpp.o: in function `main':
/home/andre/Braile2/src/main.cpp:7: undefined reference to `sf::String::String(char const*, std::locale const&)'
/usr/bin/ld: /home/andre/Braile2/src/main.cpp:7: undefined reference to `sf::VideoMode::VideoMode(unsigned int, unsigned int, unsigned int)'
/usr/bin/ld: /home/andre/Braile2/src/main.cpp:7: undefined reference to `sf::RenderWindow::RenderWindow(sf::VideoMode, sf::String const&, unsigned int, sf::ContextSettings const&)'
/usr/bin/ld: /home/andre/Braile2/src/main.cpp:8: undefined reference to `sf::CircleShape::CircleShape(float, unsigned long)'
/usr/bin/ld: /home/andre/Braile2/src/main.cpp:9: undefined reference to `sf::Color::Green'
/usr/bin/ld: /home/andre/Braile2/src/main.cpp:9: undefined reference to `sf::Shape::setFillColor(sf::Color const&)'
/usr/bin/ld: /home/andre/Braile2/src/main.cpp:17: undefined reference to `sf::Window::close()'
/usr/bin/ld: /home/andre/Braile2/src/main.cpp:14: undefined reference to `sf::Window::pollEvent(sf::Event&)'
/usr/bin/ld: /home/andre/Braile2/src/main.cpp:20: undefined reference to `sf::Color::Color(unsigned char, unsigned char, unsigned char, unsigned char)'
/usr/bin/ld: /home/andre/Braile2/src/main.cpp:20: undefined reference to `sf::RenderTarget::clear(sf::Color const&)'
/usr/bin/ld: /home/andre/Braile2/src/main.cpp:21: undefined reference to `sf::RenderStates::Default'
/usr/bin/ld: /home/andre/Braile2/src/main.cpp:21: undefined reference to `sf::RenderTarget::draw(sf::Drawable const&, sf::RenderStates const&)'
/usr/bin/ld: /home/andre/Braile2/src/main.cpp:22: undefined reference to `sf::Window::display()'
/usr/bin/ld: /home/andre/Braile2/src/main.cpp:11: undefined reference to `sf::Window::isOpen() const'
/usr/bin/ld: /home/andre/Braile2/src/main.cpp:29: undefined reference to `sf::RenderWindow::~RenderWindow()'
/usr/bin/ld: CMakeFiles/Braile2.dir/src/main.cpp.o: in function `sf::CircleShape::~CircleShape()':
/usr/include/SFML/Graphics/CircleShape.hpp:41: undefined reference to `vtable for sf::CircleShape'
/usr/bin/ld: /usr/include/SFML/Graphics/CircleShape.hpp:41: undefined reference to `vtable for sf::CircleShape'
/usr/bin/ld: /usr/include/SFML/Graphics/CircleShape.hpp:41: undefined reference to `sf::Shape::~Shape()'
/usr/bin/ld: warning: creating DT_TEXTREL in a PIE
collect2: error: ld returned 1 exit status
gmake[2]: *** [CMakeFiles/Braile2.dir/build.make:97: debug/Braile2] Error 1
gmake[1]: *** [CMakeFiles/Makefile2:83: CMakeFiles/Braile2.dir/all] Error 2
gmake: *** [Makefile:91: all] Error 2
* The terminal process "/usr/bin/bash '-c', 'cmake --build /home/andre/Braile2/build-local'" terminated with exit code: 2.
Reported by: @undefined
If you have more data that you think that is interesting from the context of the issue please reply below.
Thanks ![]()
