currently the Toradex Git server is not accessible (connection timeouts). Is there an official mirror for linux-toradex.git and u-boot-toradex.git?
For now you can try git2.toradex.com
That was fast. Thank you!
this doesn’t work for me !! even i use git2
0 0 0 0 0 0 0 0 --:--:-- 0:00:58 --:--:-- 0curl: (7) Failed to connect to git.toradex.com port 80: Connection timed out
0 0 0 0 0 0 0 0 --:--:-- 0:01:43 --:--:-- 0curl: (7) Failed to connect to git.toradex.com port 80: Connection timed out
0 0 0 0 0 0 0 0 --:--:-- 0:01:41 --:--:-- 0curl: (7) Failed to connect to git.toradex.com port 80: Connection timed out
0 0 0 0 0 0 0 0 --:--:-- 0:02:06 --:--:-- 0curl: (7) Failed to connect to git.toradex.com port 80: Connection timed out
fatal: unable to access 'http://git.toradex.com/meta-toradex-nxp.git/': Failed to connect to git.toradex.com port 80: Connection timed out
fatal: unable to access 'http://git.toradex.com/meta-toradex-bsp-common.git/': Failed to connect to git.toradex.com port 80: Connection timed out
According to the log you’ve provided you’re not using git2.toradex.com but git.toradex.com
i used this
repo init -u Index of /toradex-bsp-platform.git -b LinuxImageV2.7
I suspenct you’re experiencing problems with repo sync, not repo init.
Repo sync depends on a local xml file (.repo/manifests/default.xml) that contains git.toradex.com, until server issues are resolved you’ll need to modify that file to include git2.toradex.com.
