Git error while cloning kernel source
Hi community,
I tried to clone the kernel source code in my PC by using
git clone -b toradex_4.9-2.3.x-imx git://git.toradex.com/linux-toradex.git
But it gets stuck either after 99% of receiving objects or after completing resolving deltas.I tried with http and https instead of git but that didn’t even go for remote:counting objects. I also tried this with my colleague PC and the same result occurs. Does the same issue occurred to anyone? Any suggestions to resolve this issue is appreciated.
fatal: read error: Connection reset by peer1.72 GiB | 4.77 MiB/s
fatal: early EOF
fatal: index-pack failed
This is the error I am getting after sometime.
Thanks and regards,
Nishanth
Actually we have 2 mirrored git servers one in Europe - git1.toradex.com and one in US - git2.toradex.com
I’ve tested them and cloning of toradex_4.9-2.3.x-imx was successful on both. Most likely you have a problem with your Internet provider. Could you try to use git1 and git2 may be one of them will work better for you. If it will not help - can you try to use different Internet provider?
Hi @alex.tx ,
Thanks for your quick response,git2.toradex.com solved my issue.
Nishanth
HI @nishanth1829
Perfect that the issue is solved. Thanks for the feedback.
