root@colibri-imx7-emmc-07209890:~# weston
Date: 2023-05-05 IST
[18:00:46.460] weston 9.0.0
https://wayland.freedesktop.org
Bug reports to: Issues · wayland / weston · GitLab
Build: rel_imx_5.4.70_2.3.2_rc1+
[18:00:46.461] Command line: weston
[18:00:46.461] OS: Linux, 5.4.193-5.7.0-devel-inopsv2+git.49e4130e2197, #1 SMP Tue Apr 11 21:14:29 UTC 2023, armv7l
[18:00:46.461] Using config file ‘/etc/xdg/weston/weston.ini’
[18:00:46.462] Output repaint window is 7 ms maximum.
[18:00:46.462] Loading module ‘/usr/lib/libweston-9/x11-backend.so’
[18:00:46.462] Failed to load module: /usr/lib/libweston-9/x11-backend.so: cannot open shared object file: No such file or directory
[18:00:46.462] fatal: failed to create compositor backend
Getting above error when running weston is this correct
we are using imx7d with linux bsp 5.4.70_2.3.2
