Getting starting with the iMX8X
A number of questions:
  • What is the status for shipping production Colibri iMX8X modules?
  • I see that it comes loaded with Toradex Easy Loader. I get the impression that when Linux is loaded that the Easy Loader is overwritten - correct?
  • Do I have to worry about loading the SCFW? The SCU is already to go?
  • Where is the best place to go to get info on the SCFW API or do I have to worry about it? Almost all of my use of peripherals will be with the M4 - not the A35s. Does that make a difference?
  • What is the status of Torizon for this SOM?
  • Does Torizon include Wayland/Weston?
  • Can one use the 7" parallel panel you sell with the Colibri iMX8X? does the device tree need to be modified for this? I understand that the Colibri board only supports 18-bit color.
  • Will there be an iMX8X Verdin SOM any time soon?
Dear @prahsman
Thanks a lot for contacting Toradex. I will try to answer your questions.
    The module is still in early access phase. However, if you are interested, you can request it here and we should still be able to ship some samples:
    NXP i.MX 8X Computer-on-Module - Colibri iMX8X
    This is correct. Easy installer will overwrite itself. However, you can always reflash Toradex Easy Installer through the recovery mode:
    NXP i.MX and TI AM62x Recovery Mode | Toradex Developer Center
    Our images already include everything needed. We don’t recommend that you change anything there. Under Linux you can use devicetree to configure Pinmuxing, etc.
    We are still working on the M4 support. However, it depends on where you want to configure e.g. your pin muxing, etc. If you want to do that from M4 side you probably have to use the API. Download the SCFWKIT linked in this article: Build Custom i.MX 8/8X System Controller Firmware (SCFW) | Toradex Developer Center If you run the bin file, it will extract the sw_fw_api.pdf for you. Also see this article: System Controller Firmware 101 - Getting started - NXP Community
    It is not officially supported yet but there is a version of Torizon in the continuos integration feeds. So it’s possible to test it.
    Yes it only supports weston at the moment. To run X11 application you need to use XWayland.
    Yes the parallel panel works with the Colibri iMX8X. The Colibri standard pinout only foresees 18bit. However, the iMX8X also supports 24bits when using some pins with a non standard muxing. (see: https://docs.toradex.com/105670-colibri-imx8x-datasheet.pdf)
    I’m not aware of such plans for the moment. There will be an Apalis with iMX8X and ECC, however. What would you prefer about Verdin? What do you miss with the iMX8M Mini? Where do you see advantages/disadvantages? We’re looking forward to get some feedback, change requests, esc. about Verdin and iMX8M Mini:)
Stefan
