Getting started with Apalis Evaluation Board V1.1B and an imx8 Module - no output on Monitor through DVI-D
I just received my Boards and working on setting it up following all instructions. I however, do not get any signal output on the monitor connected to the board through DVI-D. I tried several different monitors with no luck and tried a different cable.
This is the boot up sequence I am seeing on the host computer:
U-Boot 2018.03-toradex_imx_v2018.03_4.14.78_1.0.0_ga-bringup+g25f68add54 (Jul 17 2019 - 00:34:05 +0000)
CPU:   Freescale i.MX8QM revB A53 at 1200 MHz at 62C
DRAM:  2 GiB
MMC:   FSL_SDHC: 0, FSL_SDHC: 1, FSL_SDHC: 2
In:    serial
Out:   serial
Err:   serial
Model: Toradex Apalis iMX8 QuadPlus 2GB Wi-Fi / BT V1.0B, Serial# 06517981
BuildInfo:
  - SCFW cb6f758b, SECO-FW d7523fe8, IMX-MKIMAGE dd023400, ATF d6451cc
  - U-Boot 2018.03-toradex_imx_v2018.03_4.14.78_1.0.0_ga-bringup+g25f68add54
switch to partitions #0, OK
flash target is MMC:0
Net:   eth0: ethernet@5b040000
Fastboot: Normal
Normal Boot
Hit any key to stop autoboot:  3  2  1  0
761 bytes read in 6 ms (123 KiB/s)
Running bootscript from mmc ...
## Executing script at 80280000
102464 bytes read in 11 ms (8.9 MiB/s)
Loading hdp firmware from 0x0000000084000000 offset 0x0000000000002000
Loading hdp firmware Complete
48887640 bytes read in 848 ms (55 MiB/s)
## Loading kernel from FIT Image at 86400000 ...
   Using 'config@1' configuration
   Trying 'kernel@1' kernel subimage
     Description:  Linux Kernel 4.14
     Type:         Kernel Image
     Compression:  gzip compressed
     Data Start:   0x864000dc
     Data Size:    9889576 Bytes = 9.4 MiB
     Architecture: AArch64
     OS:           Linux
     Load Address: 0x80280000
     Entry Point:  0x80280000
     Hash algo:    md5
     Hash value:   32d5bf1b0500a2aeb396d5be7ad798b0
   Verifying Hash Integrity ... md5+ OK
## Loading ramdisk from FIT Image at 86400000 ...
   Trying 'ramdisk@1' ramdisk subimage
     Description:  SquashFS RAMdisk
     Type:         RAMDisk Image
     Compression:  uncompressed
     Data Start:   0x86d6e8f0
     Data Size:    38891520 Bytes = 37.1 MiB
     OS:           Linux
     Load Address: 0xa0000000
     Entry Point:  unavailable
     Hash algo:    md5
     Hash value:   dbfb0e75a69d11056cb757aa9c9ca342
   Loading ramdisk from 0x86d6e8f0 to 0xa0000000
## Loading fdt from FIT Image at 86400000 ...
   Trying 'fdt@1' fdt subimage
     Description:  Apalis iMX8 Device Tree
     Type:         Flat Device Tree
     Data Start:   0x892859cc
     Data Size:    104517 Bytes = 102.1 KiB
     Hash algo:    md5
     Hash value:   b2b775590bd7eedf9745d550a6c5ce45
   Booting using the fdt blob at 0x892859cc
   Uncompressing Kernel Image ... OK
   Loading Device Tree to 00000000fd660000, end 00000000fd67c844 ... OK
/dma-controller@5a1f0000, 73320
/dma-controller@591F0000, 74200
/dma-controller@599F0000, 75176
Starting kernel ...
[    0.184204] psci: failed to boot CPU5 (-22)
[    0.184212] CPU5: failed to boot: -22
[    0.184216] CPU5: failed in unknown state : 0x0
[    0.314253] clk: couldn't set hdmi_lis_ipg_clk clk rate to 100000000 (-22), current rate: 84857142
[    0.445741] dmi: Firmware registration failed.
[    0.568971] imx6q-pcie 5f000000.pcie: pcie_ext clock source missing or invalid
[    0.571575] imx6q-pcie 5f010000.pcie: pcie_ext clock source missing or invalid
[    0.646157] Can't support > 32 bit dma.
[    0.731511] i.mx8-hdp 56268000.hdmi: invalid resource
[    0.900367] Can't support > 32 bit dma.
[    0.909958] fsl_lpspi 5a000000.lpspi: dma setup error -19, use pio
[    0.917473] fsl_lpspi 5a020000.lpspi: dma setup error -19, use pio
[    0.927842] NXP PHY: loading NXP PHY driver: [autonomous mode]
[    0.963821] Can't support > 32 bit dma.
[    1.192445] atmel_mxt_ts 4-004a: __mxt_read_reg: i2c transfer failed (-5)
[    1.199375] atmel_mxt_ts 4-004a: mxt_bootloader_read: i2c recv failed (-5)
[    1.206391] atmel_mxt_ts 4-004a: mxt_bootloader_read: i2c recv failed (-5)
[    1.280447] ov5640_mipi_v3 5-003c: Read reg error: reg=300a
[    1.933862] imx6q-pcie 5f010000.pcie: Speed change timeout
Running /etc/rc.local...
TDX_VER_ID="Apalis-iMX8_ToradexEasyInstaller_2.0b2-20190716"
Starting udev
[    2.529128] udevd[2388]: specified group 'kvm' unknown
$Starting haveged: haveged: haveged starting up
[  OK  ]
Certificates for RDP not found in /var/volatile
Generating RSA private key, 2048 bit long modulus (2 primes)
haveged: haveged: ver: 1.9.2; arch: generic; vend: ; build: (gcc 8.2.0 CTV); collect: 128K
haveged: haveged: cpu: (VC); data: 16K (D V); inst: 16K (D V); idx: 11/40; sz: 15528/64688
haveged: haveged: tot tests(BA8): A:1/1 B:1/1 continuous tests(B):  last entropy estimate 8.00031
haveged: haveged: fills: 0, generated: 0
e is 65537 (0x010001)
Signature ok
subject=C = CH, ST = Luzern, L = Luzern, O = Toradex, CN = (none)
Getting Private key
Certificate for RDP successfully generated
[    4.532425] udevd[2389]: specified group 'kvm' unknown
Welcome to the Toradex Easy Installer
This is a Linux based installer for Toradex modules. Currently, the installer
does not have a serial console interface. You can use the Toradex Easy Installer
via any of the available display interfaces using USB mouse/keyboard or via a
network connection using RDP. Use:
  # ip addr show eth0
to display the Ethernet IP address or use USB RNDIS at IP 192.168.11.1.
Check our documentation at:
  https://developer.toradex.com/software/toradex-easy-installer
HI @Dabd and Welcome to the Toradex Community!
Concerning your issue, could you install Toradex Easy Installer version as explained here and check if you still get the issue?
Hi @jaski.tx, thank you for your help!
I just followed those steps and installed “Toradex Easy Installer” by entering recovery mode and through USB OTG. However, the problem still persists. No output on Monitor connected to Module.
It does seem like my module already had “Toradex Easy Installer” from the serial output.
See successful install below:
alt text
Thank you,
Dana
Hi Dana
You should also check the serial console output of the console as described here.
Additionally for installing Toradex Easy Installer you can use any VNC client and connect either to 192.168.11.1 over RNDIS or to the ip address of the module over Ethernet.
Yeah, you have installed the version Bsp 2.0b2 and I rather recommend you to install Bsp 2.0b4.
Please note: I hope you are running Apalis iMX8 with heatsink since it is not recommended to run Apalis iMX8 without heatsink.
Hi Jaski,
After every system restart it seems to default back to rev 2.0b2 even though after recovery mode it installs the correct version 2.0b4 as you can see below.
Here is my serial console output: (unless you are referring to something else)
U-Boot 2018.03-toradex_imx_v2018.03_4.14.78_1.0.0_ga-bringup+gc0ff506c39 (Dec 31 2019 - 15:53:00 +0000)
CPU: Freescale i.MX8QM revB A53 at 1200 MHz at 45C
DRAM: 2 GiB
Loading Environment from MMC… OK
In: serial
Out: serial
Err: serial
BuildInfo:
  • SCFW 494c97f3, SECO-FW d7523fe8, IMX-MKIMAGE dd023400, ATF a-20190
  • U-Boot 2018.03-toradex_imx_v2018.03_4.14.78_1.0.0_ga-bringup+gc0ff506c39
Detect USB boot. Will enter fastboot mode!
Fastboot: Normal
Boot from USB for mfgtools
Use default environment for mfgtools
Run bootcmd_mfg: fastboot 0
Starting download of 2225 bytes
downloading of 2225 bytes finished
Starting download of 102464 bytes
downloading of 102464 bytes finished
Starting download of 37130512 bytes
downloading of 37130512 bytes finished
Executing script at 82e00000
Loading hdp firmware from 0x0000000082fe0000 offset 0x0000000000002000
Loading kernel from FIT Image at 83000000 …
Using ‘config@1’ configuration
Trying ‘kernel@1’ kernel subimage
Description: Linux Kernel 4.14.159-2.0.4+gfff496c2a1bd
Type: Kernel Image
Data Start: 0x830000f4
Data Size: 6676173 Bytes = 6.4 MiB
OS: Linux
Hash algo: md5
Hash value: a31874602b85bbb1d182034cbecd204f
Verifying Hash Integrity … md5+ OK
Loading ramdisk from FIT Image at 83000000 …
Trying ‘ramdisk@1’ ramdisk subimage
Type: RAMDisk Image
Data Start: 0x8365e0b0
Data Size: 30347264 Bytes = 28.9 MiB
OS: Linux
Hash algo: md5
Hash value: 14e6e434f6ab782c5c0ca4a8a2c5f518
Loading ramdisk from 0x8365e0b0 to 0xa0000000
Loading fdt from FIT Image at 83000000 …
Trying ‘fdt@1’ fdt subimage
Data Start: 0x8534f18c
Data Size: 105024 Bytes = 102.6 KiB
Hash algo: md5
Hash value: 33b82ac99dc7c9456a28f54bd479ee3e
Booting using the fdt blob at 0x8534f18c
Uncompressing Kernel Image … OK
Loading Device Tree to 00000000fd65e000, end 00000000fd67aa3f … OK
/dma-controller@5a1f0000, 73440
/dma-controller@591F0000, 74320
/dma-controller@599F0000, 75296
Starting kernel …
[ 0.184219] psci: failed to boot CPU5 (-22)
[ 0.184237] CPU5: failed to boot: -22
[ 0.304561] clk: couldn’t set hdmi_lis_ipg_clk clk rate to 100000000 (-22), current rate: 84857142
[ 0.423996] dmi: Firmware registration failed.
[ 0.513866] imx6q-pcie 5f000000.pcie: pcie_ext clock source missing or invalid
[ 0.516463] imx6q-pcie 5f010000.pcie: pcie_ext clock source missing or invalid
[ 0.569975] Can’t support > 32 bit dma.
[ 0.652662] i.mx8-hdp 56268000.hdmi: invalid resource
[ 0.828427] Can’t support > 32 bit dma.
[ 0.857555] Can’t support > 32 bit dma.
[ 1.085338] atmel_mxt_ts 4-004a: __mxt_read_reg: i2c transfer failed (-5)
[ 1.092350] atmel_mxt_ts 4-004a: mxt_bootloader_read: i2c recv failed (-5)
[ 1.099430] atmel_mxt_ts 4-004a: mxt_bootloader_read: i2c recv failed (-5)
Running /etc/rc.local…
TDX_VER_ID=“Apalis-iMX8_ToradexEasyInstaller_2.0b4-20191231”
Starting udev
System time was Mon Jan 20 22:40:28 UTC 2020.
Setting the System Clock using the Hardware Clock as reference…
System Clock set. System local time is now Mon Jan 20 22:40:28 UTC 2020.
network connection using VNC. Use:
ip addr show eth0
Toradex Easy Installer Documentation Overview | Toradex Developer Center
Hi Jaski,
It seems with every system restart of the board it resets to the default toradex installer version 2.0b2 even though as you can see below it installed v2.0b4
Here is my serial console output (unless you are referring to something else?):
DRAM:  2 GiB
In:    serial
Out:   serial
Err:   serial
 BuildInfo:
  - SCFW 494c97f3, SECO-FW d7523fe8, IMX-MKIMAGE dd023400, ATF a-20190
  - U-Boot 2018.03-toradex_imx_v2018.03_4.14.78_1.0.0_ga-bringup+gc0ff506c39
Fastboot: Normal
## Executing script at 82e00000
## Loading kernel from FIT Image at 83000000 ...
     Type:         Kernel Image
     OS:           Linux
     Hash algo:    md5
## Loading ramdisk from FIT Image at 83000000 ...
     Type:         RAMDisk Image
     OS:           Linux
     Hash algo:    md5
## Loading fdt from FIT Image at 83000000 ...
     Hash algo:    md5
   Loading Device Tree to 00000000fd65e000, end 00000000fd67aa3f ... OK
Starting kernel ...
[    0.304561] clk: couldn't set hdmi_lis_ipg_clk clk rate to 100000000 (-22), current rate: 84857142
[    0.569975] Can't support > 32 bit dma.
[    0.828427] Can't support > 32 bit dma.
[    0.857555] Can't support > 32 bit dma.
TDX_VER_ID="Apalis-iMX8_ToradexEasyInstaller_2.0b4-20191231"
Starting udev
Setting the System Clock using the Hardware Clock as reference...
  # ip addr show eth0
Thank you,
Dana
HI Dana
When you launch the recovery script, then Toradex Easy Installer is copied to the RAM of the module and booted from there.
Then you need to connect to the module by using a VNC Client and install Toradex Easy Installer by selecting it from the image shown in VNC Client. Have you done this?
Hi Jaski,
Yes, that worked. I was able to connect through VNC and install the image. No display on the monitor still but at least I was able to move on.
Thank you!
Dana
HI Dana
These are good news. Which image did you install?
Could you provide some information about your monitor?
Hi Jaski,
I used the torizon image, the monitor I am using is an HP EliteDisplay E231i 1920X1080 at 60Hz.
Thank you,
Dana
HI Dana
Which Torizon version ( uname -a ) did you install?
Could you provide a dmesg log ( dmesg > dmesg.txt )?
Thanks and best regards,
Hi Jaski,
The Torizon version is “Linux 4.14.126-0.0.0”
See attached log "dmesg.txt"link text
Please advise.
Thank you,
Dana
Greetings @Dabd,
I’m unable to recreate this issue on my end.
Just to double check a few things, so you’ve had issues getting display working via DVI-D for both our easy installer tool and the Torizon image, correct?
Could you try installing another image through easy installer and see if the problem persists?
If the issue continues then the issue might be hardware/display related. One thing to check is that jumpers X39 and X40 on the evaluation board are properly set to the DVI-D option.
Hi Jeremias,
That’s correct, I haven’t been able to get my display to work at all. I tried multiple monitors and cables.
I installed a different image - the NXP and AWS demo image - and the problem persists.
Both jumpers are set correctly to DVI.
Please advise.
Thank you,
Dana
Hi Jeremias,
I tried a monitor with an HDMI input, and a DVI-D to HDMI adapter. And that worked!!
Thank you so much!
-Dana
Hi Dana,
Could you see what the output of running fbset on the device is. It’d help to know what kind of timing information the device is parsing from the display if any at all.
Also are the cables you are trying straight DVI-D to DVI-D? If you have any DVI-D to HDMI it might be worth a shot as I recall some customers had better results with DVI-D to HDMI.
Glad it worked out for you!
