I am using apalis imx6 with angastrom-lxde-image running on it.I have developed a Qt app for GUI. My Qt app is working fine and i am able to get desired GUI on my screen. But when i am trying to play a .wav file using Qt QSound class in the same Qt program, I am getting error “PulseAudioService: pa_context_connect() failed”.
same program is working fine on windows and ubuntu(Desktop) without any error and i am able to play .wav file. Problem arises when i tries it on my apalis imx6 board.
i have already added qtmultimedia package in my yocto build, but it doesn’t help.
Hi
As we do not deploy pulseaudio in any of our images I wouldn’t know what exactly needs to be done to get a working pulseaudio installation.
E.g. things to check:
Did you check that you have pulseaudio installed in your image?
opkg list-installed | grep pulse
Is pulseaudio correctly installed and the pulseaudio server running?
Note also some other community threads in regards to pulseaudio installation.
Max
Hi..
The “PulseAudioService: pa_context_connect() failed” since the pulseaudio is not running in system mode. So what you exactly need to do is that run the following commands in the board and check the result.
- Check pulseaudio is running as a daemon.
$ ps -ae | grep pulseaudio
- Run Pulseaudio in with verbose
$ pulseaudio -vvvv
If RED color logs are there, please go through it or post below. If no error are there do ctrl +c
Start Pulseaudio as a daemon
$ pulseaudio -D -
Play a wav file using command line
$ paplay “wave file path”
if you here sound then deploy your App and try it..Most probably it should play wave file.
Vimal Babu
