I created an fresh setup of Apalis iMX6 Yocto using the steps mentioned in the documentation.
I am able to flash the build kernel image on the SD card and boot the board .
( Board is connected with an HDMI to VGA converter. The setup was proper with default factory flashed image )
But the setup throws below mentioned console message on the screen & I am not getting any display.
root@apalis-imx6:~# uname -a
Linux apalis-imx6 3.14.52-v2.6.1b1+g3894f6d #1 SMP Thu Jan 12 16:22:15 IST 2017 armv7l GNU/Linux
root@apalis-imx6:~#
[ 27.442270] mxc_sdc_fb fb.20: 640x480 h_sync,r,l: 96,16,48 v_sync,l,u: 2,10,33 pixclock=25200000 Hz
[ 27.503559] mxc_sdc_fb fb.20: 640x480 h_sync,r,l: 96,16,48 v_sync,l,u: 2,10,33 pixclock=25200000 Hz
[ 27.574334] mxc_sdc_fb fb.20: 640x480 h_sync,r,l: 96,16,48 v_sync,l,u: 2,10,33 pixclock=25200000 Hz
[ 27.643510] mxc_sdc_fb fb.20: 640x480 h_sync,r,l: 96,16,48 v_sync,l,u: 2,10,33 pixclock=25200000 Hz
[ 27.713798] mxc_sdc_fb fb.20: 640x480 h_sync,r,l: 96,16,48 v_sync,l,u: 2,10,33 pixclock=25200000 Hz
[ 33.232863] mxc_sdc_fb fb.20: 640x480 h_sync,r,l: 96,16,48 v_sync,l,u: 2,10,33 pixclock=25200000 Hz
[ 33.293524] mxc_sdc_fb fb.20: 640x480 h_sync,r,l: 96,16,48 v_sync,l,u: 2,10,33 pixclock=25200000 Hz
[ 33.364302] mxc_sdc_fb fb.20: 640x480 h_sync,r,l: 96,16,48 v_sync,l,u: 2,10,33 pixclock=25200000 Hz
[ 33.433497] mxc_sdc_fb fb.20: 640x480 h_sync,r,l: 96,16,48 v_sync,l,u: 2,10,33 pixclock=25200000 Hz
[ 33.503789] mxc_sdc_fb fb.20: 640x480 h_sync,r,l: 96,16,48 v_sync,l,u: 2,10,33
Could members please guide me as to what might be the probable cause as I am unable to access the console terminal due to these message & the HDMI output is also not working .
