I would like to use function GetProcID to determinate which Colibri board is used. Do you provide such function for VF61?
Yes there is a way to detect this. We are currently implementing SysInfo library for Vybrid. But in the mean time you can use this →
#define IOCTL_HAL_QUERY_BOARD_ID CTL_CODE(FILE_DEVICE_HAL, 3073, METHOD_BUFFERED, FILE_ANY_ACCESS)
#define BOARD_ID_VF50 0x00500000
#define BOARD_ID_VF61 0x00610000
DWORD boardid;
if (!KernelIoControl(IOCTL_HAL_QUERY_BOARD_ID,NULL,0,&boardid,sizeof(DWORD),NULL))
RETAILMSG(1, (_T("Error %d reading board id\r\n"),GetLastError()));
goto CleanUp;
When I have tried to use your example. After compilation I have got errors:
error C2065: ‘FILE_DEVICE_HAL’ : undeclared identifier
error C2065: ‘METHOD_BUFFERED’ : undeclared identifier
error C2065: ‘FILE_ANY_ACCESS’ : undeclared identifier
error C3861: ‘KernelIoControl’: identifier not found
error C3861: ‘CTL_CODE’: identifier not found
Should I include any additional headers?
# define FILE_DEVICE_HAL 0x101
# define METHOD_BUFFERED 0x0
# define FILE_ANY_ACCESS 0x0
# define CTL_CODE( DeviceType, Function, Method, Access ) (((DeviceType) << 16) | ((Access) << 14) | ((Function) << 2) | (Method))
# define IOCTL_HAL_REBOOT CTL_CODE(FILE_DEVICE_HAL, 15, METHOD_BUFFERED, FILE_ANY_ACCESS)
extern "C" {
BOOL KernelIoControl(DWORD dwIoControlCode, LPVOID lpInBuf, DWORD nInBufSize, LPVOID lpOutBuf, DWORD nOutBufSize, LPDWORD lpBytesReturned);
Add this entries and it should work. Its also documented on developers network.
Now it works fine.
Thank you.
Konrad
