Get support Colibri VF61 USB (willing order support hours)
Dear community,
We are noticing a problem with the USB on the VF61 Colibri module. When the SOM exits sleep mode, the USB sometimes appears to hang and does not resume. This causes the connected devices to stop working until the module is reset.
Is this a known issue to Toradex? If so, is it possible to get support for developing a solution? We would be willing to order Support Hours if necessary.
Thank you!
USB Resume Issues After Sleep Mode on Colibri VF61
Based on the available documentation, there are known limitations with USB functionality on the Colibri VF61 module after sleep/resume cycles.
Known USB Sleep/Resume Limitations
The current implementation on Colibri VF61 has specific limitations regarding USB wake-up functionality (1). According to the technical documentation, the current implementation does not include USB wakeup (1). This means that USB devices cannot be used as wake-up sources, and there may be related issues with USB functionality after the module resumes from sleep mode.
Sleep Mode Details
The Colibri VF61 supports several low-power states (2):
  • LPStop3: Selected power rails are switched off (e.g., 1.2V Core is switched off). First 16K SRAM is retained
  • LPStop2: Selected power rails are switched off (e.g., 1.2V Core is switched off). First 16K SRAM is retained
  • LPStop1: Selected power rails are switched off (e.g., 1.2V Core is switched off). SRAM content is lost
  • VBAT: Only the RTC battery voltage (VCC_BATT) is available
Since normal GPIO pins lose their state in LPStop3 mode and lower, only pins which are wake-up capable can generate an interrupt to wake up the system (2).
USB Hardware Configuration
The Colibri VF61 provides two USB 2.0 High Speed ports that can be configured independently as host or client (3). The USB control signals include power enable and overcurrent detection capabilities (3), but the sleep/resume functionality appears to have limitations.
Alternative Wake-Up Methods
For reliable wake-up functionality, you should consider using GPIO-based wake-up sources instead of USB. The documentation suggests that proper wake-up implementation requires specific GPIO configuration in the device tree (1).
Recommendation
Given that this appears to be a known limitation with the current USB implementation on Colibri VF61, I recommend implementing alternative wake-up mechanisms using GPIO pins that support wake-up functionality. The USB resume issue you’re experiencing aligns with the documented limitations of the current implementation.
For detailed technical support and potential workarounds specific to your application, professional support services would be beneficial to develop a custom solution that works within the hardware constraints.
Hi @RIki89d!
Are you using WinCE or Linux (BSP)?
Best regards.
Hello @lucas_az.tx
I am currently using Windows CE 6.0
Hi @RIki89d ,
Does the issue only affect USB Devices? Everything else works when exiting Sleep mode?
Does a replug help?
We were not aware of this issue so far… what kind of USB devices are you using? (so we can try to reproduce it)
Hello @germano.tx
That issue only affect to USB plugged devices.
We had tried diferent scenarios:
1- Connect a HUB with 3 devices (a BLE mouse/keyboard pen, USB Modem (RNDIS) and a pendrive)
In the scenario described abouve, all devices stop working after resume, sometimes, one of them stop working and other still working, it is totally random.
2- Connect just one USB (no HUB) on the USB port
In this scenario, for example, if we connect a touch display, it works, however, after exist sleep mode, sometimes it stop working….
Replug most of the times doesn’t solve the issue, you need restart the entire system.
We also tried differents HUB, but same happens.
Also, we have a BLE USB receptor like this one:
https://www.amazon.es/Adaptador-Bluetooth-Conecte-Memoria-Compatible/dp/B0BW97QCTX?th=1
When we plug this, USB directly stop working (it happens all the time we plug it).
Also noticed that, when we run Linux system (Angstrom, provided by toradex) this issue never happend, it works very well, that is why whe think a Windows problem could cause this.
dear @germano.tx , did you get reproduce it on your side?
We also tried it on Iris dev board, and also happend…
Thank you so much.
Hi @RIki89d ,
Sorry for the long delay.
I tried to reproduce the issue but unfortunately could not reproduce it.
I’m using the Colibri Evalboard (which had an integrated USB Hub) und i have a USB Stick + USB Mouse connected to it. Going to suspend and resuning several times, both USB devices work after resume.
I don’t have a USB RNDIS Modem to test with.. maybe that’s the difference??
Maybe it depends on your Suspend/resume settings/triggers..
I use the Start Menu → Suspend
and i use a SDCard insertion as a trigger to wake the system up
