General Purpose Timer GPT interrupts
I want to use the “General Purpose Timer” GPT.
But the linker can not find “setup_irq”.
Please, where can I get the library for iMX66DL including “setup_irq” ?
Thank you for your help.
How and what exactly are you trying to do? Are you trying to compile a kernel module outside of the kernel source tree?
This is not a bummer at all as it protects the overall system from potential dangerous things being done to it.
Hi
Are you trying to write a linux user-space program that is configuring and using interrupts?
If yes, that is simply not possible.
You will have to write a kernel driver that handles the low latency requirements of your application.
Max
Hallo,
thank you for your response.
I need interrupts any 10 µs.
Without Interrupts I can achive cycles not less than 60 µs.
So I want to use the GPT_COMPARE2 Register, IRQ81 with GPT_IR OF2IE.
I read GPT_IR and could see that GPT_COMPARE1 seems to be used already.
I set GPT_IR OF1IE to low to stop that interrup, but could not notice any effect. So I can not say what GPT_COMPARE1 is used for.
Now I need “setup_irq” because I do not want to care about the GIC-device.
Best regards
Hallo Max,
thank you for your reply.
I noticed it already.
With “mmap” I get access to GPIO, GPT, IOMUXC and SCU.
But I can’t get Access to the GIC.
To put a Programm to annother space is a second issue.
Bummer!
