Hello everyone,
I’ve been trying to compile some C files in a development and in this new BSP something broke. I just did the same as always opkg install packagegroup-core-buildessential
I don’t know if this was on the Angstrom repositories of if it is BSP related.
While compiling a test.c this is my output
gcc test.c -o test
Output:
/usr/lib/gcc/arm-angstrom-linux-gnueabi/7.2.0/../../../../arm-angstrom-linux-gnueabi/bin/ld: error: cannot open crtbegin.o: No such file or directory
/usr/lib/gcc/arm-angstrom-linux-gnueabi/7.2.0/../../../../arm-angstrom-linux-gnueabi/bin/ld: error: cannot open crtend.o: No such file or directory
/usr/lib/gcc/arm-angstrom-linux-gnueabi/7.2.0/../../../../arm-angstrom-linux-gnueabi/bin/ld: error: cannot find -lgcc
/usr/lib/gcc/arm-angstrom-linux-gnueabi/7.2.0/../../../../arm-angstrom-linux-gnueabi/bin/ld: error: cannot find -lgcc_s
collect2: error: ld returned 1 exit status
I think in this new version that only GCC7 is available and somehow broke the compiler
I don’t know if it’s $PATH’s fault but here it is
/sbin:/bin:/usr/sbin:/usr/bin:/usr/local/bin:/usr/bin:/bin:/usr/local/sbin:/usr/sbin:/sbin
Some help would be appreciated. Best Regards,
