Thanks for the reply.
I am looking for enabling D2XX from Kernel. By default, the kernel loads VCP/ ftdi_sio.
I found some tips that ‘unbinds’ the default driver then D2XX can be used but no success.
Any other suggestion ?
Hi Alex,
I am not sure if I get your answer right? Or my question was unclear ?
Yes the ftdi_sio is loaded when an FTDI device is plugged in. From the FTDI manuals, it looks like that this driver needs to be unloaded and a ftd2xx driver needs to be loaded in prior to using the D2XX interface.
Is there a way to switch from FTDI VCP to D2XX and from D2XX to FTDI VCP without restarting the system ?
My device reported 0403:6001 for both cases.
I changed the EEPROM of the FTDI device to use D2XX driver. It works for Windows 10 but Torizon still detects it as VCP.
Maybe I need to change the PID in order to use D2XX as your example.
