Free GPIOs on IMX7 running WEC2013
Dear Team,
I want to use the iMX7 in my System without any physically connected display running WEC2013. I started with the schematics of the IRIS V1.1 board and the iMX7D maunual and tried to figured out, which gpios were available.
Due to a bug of the SPI driver I found out earlier and no chance that this bug get fixed I was told by Toradex to use SODIMM 133 as a manual nCS. And I have to use tis pin exclusively, so no other usage of this GPIO 2 module is allowed. ==> GPIO2 is only godd for that nCS.
This gives the list of remaining GPIOs:
GPIO1.P1
GPIO1.P2
GPIO3.P23
GPIO3.P24
GPIO3.P25
GPIO3.P26
GPIO3.P27
GPIO3.P28
GPIO4.P13
GPIO4.P14
GPIO4.P15
GPIO4.P16
GPIO4.P17
GPIO4.P18
GPIO4.P19
GPIO4.P20
GPIO4.P21
GPIO4.P22
GPIO5.P11
GPIO5.P12
GPIO5.P13
GPIO5.P16
GPIO5.P17
GPIO6.P16
And, if using any of that free GPIOs, please note, that toggling a pin within an ISR also means, that that the whole GPIO bank isn’t available for other threads!!
Is the above list correct, or is some of the GPIO-banks, or ports still used by WEC2013?
Thanks a lot for helping.
With best regards
Gerhard
Dear @Gerhard
First let me render your statement about GPIO bank reservation more precisely:
It is critical to have multiple parallel threads writing to the same GPIO bank - the i.MX6 does not feature Bit-Set and Bit-Clear registers for GPIOs, therefore read-modify-write operations are required to change single bits. If such a read-modify-write is interrupted by a write to the same register, the result is unpredictable.
Using GPIO inputs in parallel threads is perfectly fine, as long as only one thread is writing to the register, or as long as read-modify-write operations are synchronized, for example by the use of a mutex.
The GPIOs you listed in your question are not occupied by WEC2013, you are free to use them for your own application.
Regards, Andy
Dear @Gerhard
I mised to add a few restrictions regarding the GPIOs:
  • GPIO3.P23-P28 could be used by the display controller. Make sure you use only 18 bits per pixel (not 24)
  • GPIO4.P20 / P21 are shorted on the module to GPIO2.P3 (PWM_D) / GPIO2.P0 (PWM_A). Of course only one of the two shorted functions can be used at any time
Regards, Andy
