Folders and files cannot be seens after installing .NETCF3.5
I’m trying to install .NETCF 3.5 in flashdisk. I’m able to do so successfully. But as soon as i install it, all files and folders from flashdisk get vanished.
When I try to create a folder with the same name, it says the folder already exists. I have checked View hidden files and folders. Still I cannot see it.
Bootloader Var 1.6
image var 1.6 (WinCE7)
Hi @kshah ,
On which module you are facing this issue?
Col IMX6 DL 512MB V1.1A
WinCE7
I can confirm this issue and we will investigate it. As a workaround you can recreate deleted folders after system reboot.
This issue is caused by incorrect TRIM fuction implementation. It will be fixed at next BSP release. Please disable this feature by setting [HKEY_LOCAL_MACHINE\Drivers\SDCARD\ClientDrivers\Class\MMC_Class\High_Capacity] EnableTrim=dword:0 for now.
