I am using OE Core 2.6.1 version for my VF61 , is there any way to add fluentd logging application in target and sdk ?
Thanks, I Understand I can add fluentbit recipe from mate-oe layer by this method,
IMAGE_INSTALL_append = " fluentbit"
if I am correct, how can i list the already added recipes in my image ,
how about
bitbake -e | grep ^IMAGE_INSTALL
Note that that shows what packages got added to the IMAGE_INSTALL variable, not what gets pulled in through dependencies these packages have.
After you built the image have a look at files in
build/buildhistory/image//glibc/
Max
then I got this error
> Nothing RPROVIDES 'fluentbit' (but
> /home/naveen/oe-core/build/../layers/meta-toradex-demos/recipes-images/images/console-trdx-image.bb
> RDEPENDS on or otherwise requires it)
Did you check that the fluentbit recipe is available in your installed layers? Maybe you need to update your layers to a newer version (e.g. to V2.7 which uses morty) or you need to backport the recipe to your setup.
Max
