I have an imx8qm 1.1C I have been using for development. Recently I wanted to to upgrade with a custom built torizon image and thus needed to flash TEZI on it.
But it seems the process is not completing. The device is detected and flashing seems to start but it seems its not completing. On the host side this is what I get and the script doesn’t exit.
U-Boot 2018.03-toradex_imx_v2018.03_4.14.98_2.3.0_bringup+g52f89f8382 (Apr 15 2021 - 17:12:01 +0000)
CPU: Freescale i.MX8QM revB A53 at 1200 MHz at 31C
DRAM: 4 GiB
In: serial
Out: serial
Err: serial
Model: Toradex Apalis iMX8 QuadMax 4GB Wi-Fi / BT IT V1.1C, Serial# 06852170
BuildInfo:
- SCFW b929edfe, SECO-FW 27167ff2, IMX-MKIMAGE d7f9440d, ATF bb209a0
- U-Boot 2018.03-toradex_imx_v2018.03_4.14.98_2.3.0_bringup+g52f89f8382
switch to partitions #0, OK
Detect USB boot. Will enter fastboot mode!
flash target is MMC:0
Net: eth0: ethernet@5b040000
Fastboot: Normal
Boot from USB for mfgtools
Use default environment for mfgtools
Run bootcmd_mfg: select_dt_from_module_version && fastboot 0
Apalis iMX8 #
I tried with putting device in recovery mode and waiting more than 10 seconds. Still no change. The script does not exit at all. This is the reason we are not getting the flashing exit status.
its really behaving strange I would say. I have previously flashed the same module the same way with even the same TEZI release with no issues at all. But now its not exiting.
Attached you will see the latest attempt to flash it. The terminal on the far left shows module was in recovery more than 10 seconds before launching the script. As you can see from the middle screen the script did not exit. On the extreme right is the debug port of the module. it was blank before the script started. after the script starting you can see it drops to the uboot terminal and nothing happens afterwards however long I wait.
Can you share the specific setup that you used?
What version of the module and the carrier board did you use in your case?
Also what version of the Toradex Easy Installer did you use?
@keven.tribe
You can see in the article of the recovery mode that you have to remove JP2 to use the OTG port in client mode.
I tried your setup here on my desk and by removing the jumper you surely should be able to recover it.
The USBO1_ID on my board is pulled high to 3V3 by default which I believe should not be an issue since I have flashed the board several times before using the same recovery process. I checked the status of the Pin and its indeed high.
I tried again to flash but with same results. Could there be a possibility that the module is damaged partially? Since it can’t be flashed but can drop into uboot without responding to keyboard inputs.
I have tried using 2 similar carrier boards with similar results. I am out of ideas at this point.
I received your module. I did some initial tests and I was successfully flashing different TEZI versions onto it. The keyboard inputs were also recognized, as I followed it up by installing the Toradex Minimal Reference Image.
Looking again at your pictures, what you see here is the first “loading bar” the shows you if the device was recognized. Usually after this one you would see another “loading bar” with a counter that counts to 10.
Did you try to use a Toradex Carrier Board instead?
Could you maybe explain in more detail what steps you are going through to flash TEZI onto the module?
That’s strange. Well good thing is module is not damaged.
If now I think about it. I tried the flashing on 2 of my carrier boards but used the same serial cable and usb cable for debug and flashing respectively.
For the usb cable I made it myself by adding another USB-A in the position of a micro USB. So that I could have USB-A to USB-A on both sides. When I had these issues I did check if the connections are all OK for the flashing USB, but didn’t check the serial debug cable. Can a damaged serial cable that’s connected to the debug port prevent tezi from finishing the flashing?
Thanks for clarifying. So that means that the OTG port you use is a USB-A port?
Could you maybe share a snipped of your schematic, where we could see the USB connector?
I would not expect, that a damaged serial cable on the debug port would have any effect on the flashing of tezi.
I tried on 2 carrier boards with the same result. Attached is the sch for the OTG port. I have however flashed the module multiple times from the same port. So there is something that seems to be off.
