Colibri iMX6ULL 512MB IT:
Eval board brought ethernet pins of Micrel KSZ8041 to the RJ45 kept at the front panel. I never use the Micrel KSZ8041 ethernet pins.
I am going to implement ethernet using MII interface connected to external switch. The switch is having four 100Mbps ethernet ports.
Is it possible to use above ethernet ports to update image using TFTP?
