Hi I’m trying to flash Linux on a old Calibri board, which is currently running a WindowsCE.
I’ve downloaded Colibri-T20_LXDE-Image_2.8.7 from your website and have troubles to send the image to the device:
Colibri T20 V1.2A
Carrier Board Colibiri Evaluation V3.2B
If I reboot the board I get the info I’m running
Toradex Bootloader 1.4 BETA for Tegra Build Feb 17 2015
So I did following on my linux host (Open SuSE):
Colibri-T20_LXDE-Image_2.8.7 # mount /dev/sdb1 /mnt
Colibri-T20_LXDE-Image_2.8.7 # mount | grep /mnt
/dev/sdb1 on /mnt type vfat (rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=iso8859-1,shortname=mixed,errors=remount-ro)
Colibri-T20_LXDE-Image_2.8.7 # ./update.sh -o /mnt
Colibri T20 rootfs detected
Image file colibri_t20-256-v11-nand.img has been successfully generated!
Image file colibri_t20-256-v12-nand.img has been successfully generated!
Image file colibri_t20-512-v11-nand.img has been successfully generated!
Image file colibri_t20-512-v12-nand.img has been successfully generated!
mkfs.ubifs
root: rootfs/
min_io_size: 4096
leb_size: 253952
max_leb_cnt: 4084
output: colibri-t20_bin/ubifs_248KiB.img
jrn_size: 8388608
reserved: 0
compr: lzo
keyhash: r5
fanout: 8
orph_lebs: 1
space_fixup: 1
super lebs: 1
master lebs: 2
log_lebs: 4
lpt_lebs: 2
orph_lebs: 1
main_lebs: 738
gc lebs: 1
index lebs: 13
leb_cnt: 748
UUID: 7FE7A7A8-C44F-4D71-BC6F-5C1EFB4BE16C
Success!
mkfs.ubifs
root: rootfs/
min_io_size: 4096
leb_size: 516096
max_leb_cnt: 4084
output: colibri-t20_bin/ubifs_504KiB.img
jrn_size: 8388608
reserved: 0
compr: lzo
keyhash: r5
fanout: 8
orph_lebs: 1
space_fixup: 1
super lebs: 1
master lebs: 2
log_lebs: 4
lpt_lebs: 2
orph_lebs: 1
main_lebs: 363
gc lebs: 1
index lebs: 7
leb_cnt: 373
UUID: 07464C83-405B-40E0-BF10-46A01E076D6D
Success!
UBI image of root file system generated, copying data to target folder...
Successfully copied data to target folder.
To flash the Apalis/Colibri T20/T30/TK1 module a running U-Boot is required. Boot
the module to the U-Boot prompt and
insert the SD card, USB flash drive or when using TFTP connect Ethernet only
and enter:
'run setupdate'
then to update all components enter:
'run update'
Alternatively, to update U-Boot enter:
'run update_uboot'
to update a component stored in UBI enter:
'run prepare_ubi' (for Colibri T20)
followed by one of:
'run update_kernel'
'run update_fdt' (for device tree enabled kernels)
'run update_rootfs'
If you don't have a working U-Boot anymore, connect your PC to the module's USB
client port, bring the module into the recovery mode and start the update.sh
script with the -d option. This will copy U-Boot into the module's RAM and
execute it.
Now I plug the sdcard into the carrier board, and boot the device into recovery mode. I can see the USB device now on the host linux:
Colibri-T20_LXDE-Image_2.8.7 # lsusb | grep NV
Bus 003 Device 033: ID 0955:7820 NVIDIA Corp. T20 [Tegra 2] recovery mode
Now I try to send the u-boot command to the board:
Colibri-T20_LXDE-Image_2.8.7 # ./update.sh -d -r256 -vV1_2
bct file: ../colibri-t20_bin/colibri_t20-256-v12-nand.bct
bootloader file: ../colibri-t20_bin/u-boot-dtb-tegra.bin
load addr 0x80108000
entry addr 0x80108000
./tegrarcm: could not open USB device: No such device
That’s it. The USB device disappeard on linux host and nothing happens anymore. If I reboot the board, WindowsCE starts again. What I’m doing wrong?
Thanks for your help!
colibri linux colibri-t20 t20 boot install
