Flashing Apalis Board
Hello everyone!
When loading an image with EasyInstaller an error occurred on the board. When restarting it, the following message appears:
mmc_load_image_raw_sector: mmc block read error
SPL: failed to boot from all boot device
### ERROR ### Please RESET the board ###
I tried to run EasyInstaller or load an image from the SD card but I could not. What should I do to have an image working again?
Tanks
Pablo
What exact versions of things (e.g. Toradex Easy Installer and Demo Image) are you talking about?
Tanks Marcel!
At the time I failed image it was an image created by me. My question is how do I make the board work again? When it start, just type that text. I can not write commands in uboot. I do not know what steps to follow to solve the problem. Should I short-circuit 1K resistance for recovery mode?
Note that the SoC on our i.MX 6 modules are fused to boot from eMMC. So this is typically not an option.
Yes your best bet is using the recovery mode. You can use tweezers to temporarily put the SoC into recovery mode. See also the video on the Toradex Easy Installer article.
