I understand you’re experiencing flashdisk corruption issues with WinCE 6 Image Version 1.9, particularly when installing Compact Framework 3.5. Based on the available documentation, I can provide some guidance on Toradex WinCE features and troubleshooting approaches.
WinCE Compact Framework Support
According to the Toradex documentation, the .NET Compact Framework is supported as an installable feature that can be added to the WinCE image(1). The documentation mentions that you can add WinCE features like the .NET Compact Framework without building your own image(1).
Known Issues and Troubleshooting
The documentation indicates that there have been various issues addressed across different WinCE releases(2). For specific issues like flashdisk corruption and bad block errors, the documentation suggests checking the Release Details page for information about fixed and pending issues(2).
Registry Configuration Options
The Toradex WinCE system provides extensive registry-based configuration options(1). The documentation states that through the Windows registry, it’s possible to configure the behavior of the WinCE operating system in almost every area, including:
- Display interfaces and settings(1)
- Audio and touch screen controller settings(1)
- Driver management (disable drivers that are not required)(1)
- USB stack configuration(1)
Update Recommendations
When updating WinCE images, the documentation emphasizes several important points(2):
- If updating both bootloader and image, both must be updated before rebooting(2)
- Registry changes may be required between versions(2)
- Some versions require clearing the registry to maintain default behavior(2)
Next Steps
For your specific flashdisk corruption issue with Version 1.9 and Compact Framework 3.5 installation, I recommend:
- Check Release Notes: Review the WinCE BSP Release Details for Version 1.9 specific known issues(2)
- Registry Reset: Consider clearing the registry if transitioning between versions(2)
- Alternative Installation: Try using the binary WinCE image approach rather than building custom images(1)
The documentation suggests that using the tested binary images is often more reliable than custom builds, as they are tested by Toradex and thousands of customers(1).
