How do I flash only the device-tree binary on a iMX7 eMMC module? Previously (non eMMC) I’ve used the run setupdate, run prepare_ubi, run update_fdt from u-boot, but these seems not supported on the eMMC module.
I would like to upgrade only the device-tree (and kernel) without re-flashing the entire image using the easy-installer.
Thanks! I noticed /boot is empty, but the kernel zImage and dtbs are located at /media/mmcblk0p1. (that is, /dev/mmcblk0p1 is mounted at /media/mmcblk0p1). Has there been a change in the mount location on my system?
Yes, that’s the partition that uboot will load the kernel and the device tree from. Normally it should be mounted to /boot via /etc/fstab, but it works even if it isn’t. You can replace the .dtb you find there.
Please ask a new question exactly starting what it is you are trying to achieve and what exact hardware and software versions of things you are talking about.
