Hi @pontusoim,
For your docker container to initialize with your OS, you can use TorizonCore Builder. You need to add your docker-compose to your image by editing your tcbuild.yaml. If you run torizoncore-builder build --create-template, it will create a template for you with all possible configurations and some useful commentaries:
# >> NOTES:
# >> Lines containing ">>" are simply comments explaining the properties that
# >> follow; if you don't like these comments run:
# >> $ grep -v '>>' tcbuild.yaml > tcbuild-clean.yaml
# >> A line not containing ">>" can be uncommented (by removing the hash mark
# >> plus a space from its beginning); also set the corresponding property to
# >> appropriate values.
# >> When uncommenting a line having a property, remember to uncomment all its
# >> parent properties as well; for example: if you uncomment the
# >> 'splash-screen' property, also uncomment its parent property called
# >> 'customization'.
# >> The input section specifies the image to be taken as the base for the
# >> customization.
input:
easy-installer:
# >> Choose one of the options (REQUIRED):
# >> (1) Image as local folder or tarball.
# local: torizon-core-docker-apalis-imx6-Tezi_5.2.0-devel-202104+build.11.tar
# >> (2) Remote file (optionally with a filename and or a sha256 checksum):
# remote: "https://artifacts.toradex.com/.../torizon-core-docker-apalis-imx8-Tezi_5.1.0%2Bbuild.1.tar"
# remote: "https://artifacts.toradex.com/.../torizon-core-docker-colibri-imx6-Tezi_5.0.0-devel-202009%2Bbuild.2.tar;filename=torizon-core-docker-colibri-imx6-Tezi_5.0.0-devel-202009+build.2.tar;sha256sum=368595fa3fb00af9604e70311de3b04df6b30b280deec2f8918c46f479026ddb"
# >> (3) Image specification (URL will be generated by the tool)
# toradex-feed:
# version: "5.1.0"
# release: quarterly
# machine: colibri-imx7-emmc
# distro: torizon-upstream
# variant: torizon-core-docker
# build-number: "1"
# # build-date: "20210408"
# >> The customization section defines the modifications to be applied to get
# >> the desired output image.
# customization:
# >> Splash screen:
# splash-screen: custom-splash-screen.png
# >> Directories overlayed to the base OSTree
# filesystem:
# - changes/
# device-tree:
# >> Directories where to look for include files.
# include-dirs:
# - device-trees/include/
# >> Custom device tree source:
# custom: device-trees/dts-arm32/imx6ull-colibri-eval-v3.dts
# >> Device-tree overlays configuration:
# overlays:
# >> Whether to ignore all overlays from the base image (or ostree
# >> archive in the future).
# clear: false
# >> Specific overlays not to use from base image (useful only when
# >> clear is false and not DT has been selected).
# remove:
# - apalis-imx8_hdmi_overlay.dtbo
# >> Overlays to add to output image.
# add:
# - device-trees/overlays/display-edt7_overlay.dts
# kernel:
# >> Custom kernel arguments.
# arguments:
# - key1=val1
# - key2=val2
# >> Modules to build and possibly load automatically.
# modules:
# - source-dir: virtual_touchscreen/
# autoload: false
# >> The output section defines properties of the output image.
output:
# >> OSTree deployment configuration (relevant also for Easy Installer output).
# ostree:
# branch: my-dev-branch
# commit-subject: "OSTree commit subject"
# commit-body: "OSTree commit body"
# >> Parameters for deploying to an Easy Installer image.
easy-installer:
# >> Output directory of the customized image (REQUIRED):
local: output_directory
# >> Information shown by Toradex Easy Installer:
# name: "My customized image"
# description: "My customized image (description)"
# licence: files/custom-licence.html
# release-notes: files/custom-release-notes.html
# bundle:
# >> Choose one of the options:
# >> (1) Specify a docker-compose file whose referenced images will be downloaded.
# >> Properties platform, username, password and registry are optional.
# compose-file: files/docker-compose.yml
# platform: linux/arm/v7
# username: "${USERNAME}"
# password: "${PASSWORD}"
# registry: hub.docker.com
# >> (2) Specify a local directory containing the bundled images (previously
# >> obtained by 'torizoncore-builder bundle' command).
# dir: bundle/
# >> Provisioning configuration:
# provisioning:
# >> For "online" mode, properties "shared-data" and "online-data" must be specified.
# >> For "offline" mode, property "shared-data" must be specified alone.
# mode: "online"
# shared-data: "shared-data.tar.gz"
# online-data: "${ONLINE_PROVISIONING_DATA:?online provisioning data not supplied}"
In your tcbuild.yaml you need to add your docker-compose file under output:
output:
easy-installer:
bundle:
Don’t forget to uncomment these lines and also to select a TorizonCore image (just like this example: Customization Examples | Toradex Developer Center).
Finally, you can run torizoncore-builder build and our tool will automatically parse this file and create a custom image for you. If you’re using the above template, your image will be inside a folder called output_directory. You can simply take the file inside this folder, put into a storage device and flash it through Torizon Easy Installer. Don’t forget to change the autoinstall = true in your image.json file.
You need to add them to your Dockerfile. You will COPY the necessary python files inside your Docker image and then use the ENTRYPOINT to start your script automatically (Dockerfile reference | Docker Docs). For example, you can add this to your Dockerfile and then build your container:
COPY /home/my_computer/main.py /home/root/
ENTRYPOINT ["python3", "/home/root/main.py"]
So when your container starts, it will start your python file automatically.
I hope this will make things clearer for you.
Let me know if you need extra help with that.
Hiago.
